Hi I have a approx 20 Zigbee devices which I can't get working in a mesh. If fact I'm a bit lost where to start because everything I touch feels buggy.
The plugin is working (Zigbee1)
6 test devices have been added and are working (Zigbee2)
However no mesh is being built (Zigbee3)
Furthermore the mesh in the plugin seems having bugs it builds several.
What might be the issue that the mesh is not being shown/built?
Struggling with Zigbee
JanVlietland
- Zigbee3.png (39.38 KiB) Viewed 726 times
- Zigbee2.png (91.13 KiB) Viewed 726 times
- zigbee1.png (30.37 KiB) Viewed 726 times
JanVlietland
Re: Struggling with Zigbee
I also get these error which I don't understand:
Time: "05/09/2023 21:10:15"
Module: "Cluster"
nwkid: "eaee"
PluginHealth: "Ready"
message: "ReadCluster - Error/unknow eaee/01 Cluster: e000 Attribute: d003 Status: 00 DataType: 42 DataSize: 0004 Data: 41414141"
PermitToJoin: Object {"Duration":0,"Starttime":1693939245}
Thread: "ZigpyForwarder_3"
DeviceInfos: Object {"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"8d","Heartbeat":"1","RIA":"0","LQI":40,"Battery":{},"Model":"TS0001","ForceAckCommands":[],"MacCapa":"8e","IEEE":"a4c1387791007339","Type":"Switch","ProfileID":{},"ZDeviceID":{},"App Version":72,"Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":[],"LogicalType":"Router","Manufacturer":"1141","Manufacturer Name":"_TZ3000_kqvb5akv","NbEp":"","PowerSource":"Main","ReceiveOnIdle":"","Stack Version":"","Stamp":{"time":xxx,"Time":"2023-09-05 21:10:17","MsgType":"8048","LastSeen":"05/09/2023 21:10:17"},"ZCL Version":3,"Health":"Live","Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"ZCLSQN":"24","ZDPSQN":"12","RollingLQI":[44,64,56,64,52,48,40,40,44,40,48],"Param":{"PowerOnAfterOffOn":2},"ConfigSource":"DeviceConf","Ep":{"01":{"0000":{"0004":"_TZ3000_kqvb5akv","0000":3,"0001":72,"0005":"TS0001","0007":1,"fffe":0,"ffe2":56,"ffe4":1},"0004":{},"0005":{},"0006":{"4001":0,"4002":0,"8002":"2","0000":"01"},"0019":{},"Type":"Switch","ClusterType":{"26":"Switch"},"e000":{"d003":"41414141","d001":"06","d002":"0a"},"e001":{"d030":0,"d000":0,"d001":"00000000","d002":0,"d003":0,"d004":0,"d005":0},"0b04":{"0505":235,"0508":110,"050b":19},"0702":{"0000":0}}},"PairingInProgress":false,"PairingTime":yyy,"CheckParam":false,"CertifiedDevice":true,"ZCL-IN-SQN":{"0000":"9b","e000":"8f","0006":"90","e001":"8c","000a":"16","0b04":"18","0702":"19"},"_rawNodeDescriptor":"1141004200422a00008e424001","Max Buffer Size":"42","Max Rx":"0042","Max Tx":"0042","macapa":"8e","bitfield":"4001","server_mask":"2a00","descriptor_capability":"00","PreviousStatus":"Leave","SQN_000a":"16","ReadConfigureReporting":{"Ep":{},"Request":{"Status":"Requested","Retry":0,"TimeStamp":0}},"BindingTable":[{"Devices":[],"SQN":0,"Status":"","TimeStamp":"05/09/2023 20:39:58","Time":"05/09/2023 20:39:58"}],"WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"e000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"e001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0b04":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0702":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"ReadAttributes":{"Ep":{"01":{"0006":{"TimeStamp":"05/09/2023 21:10:17","iSQN":{"0000":"24"},"Attributes":{"8002":"00"},"ZigateRequest":{}}}}}}
context: Object {"MsgClusterId":"e000","MsgSrcEp":"01","MsgAttrID":"d003","MsgAttType":"42","MsgAttSize":"0004","MsgClusterData":"41414141"}
Module: "Cluster"
nwkid: "eaee"
