I see now that i cannot see the zwave aeontec zwave stick settings in the hardware. I can set on off the switches. thats working bur i cannot see the network etc. I run domoticz in docker on a raspi 4B+
Anton
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
zwave stick no settings
antonlamers
- Domoticz version: 2021.1
- Naamloos.jpg (70.72 KiB) Viewed 1253 times
- Naamloos2.jpg (54.99 KiB) Viewed 1253 times
Greating,
Anton
Version: 2023.2
Anton
Version: 2023.2
- gizmocuz
Re: zwave stick no settings
Did you cleared your browser cache? Or tried in a private browser mode?
OpenZWave is removed from the current beta version and will also be removed from feature stable releases.
You should switch to zwave-js-ui with MQTT Auto discovery (docker compose)
antonlamers
Hi @gizmocuz
yes it works now but, what is the rationale behind removing the z wave plugin? this is easy as it is now. it works out of the box.
Greating,
Anton
Version: 2023.2
Anton
Version: 2023.2
- Domoticz version: 2026.3
The Openzwave project that Domoticz uses is not maintained anymore: https://github.com/OpenZWave/open-zwave
lost
Could have remained for legacy stuff... Not so much rfx products coming as zigbee takes it all... Will this be removes someday?waltervl wrote: Sunday 06 August 2023 11:29 The Openzwave project that Domoticz uses is not maintained anymore: https://github.com/OpenZWave/open-zwave
rron
Rfx products have new software updates. I think that if zwave was changed for zwavejsui intergrated in domoticz the problem is less.lost wrote: Sunday 06 August 2023 12:02Could have remained for legacy stuff... Not so much rfx products coming as zigbee takes it all... Will this be removes someday?waltervl wrote: Sunday 06 August 2023 11:29 The Openzwave project that Domoticz uses is not maintained anymore: https://github.com/OpenZWave/open-zwave
Due to not maintaining the OpenZwave anymore by the Openzwave team would also lead to Domoticz build issues...lost wrote: Sunday 06 August 2023 12:02Could have remained for legacy stuff... Not so much rfx products coming as zigbee takes it all... Will this be removes someday?waltervl wrote: Sunday 06 August 2023 11:29 The Openzwave project that Domoticz uses is not maintained anymore: https://github.com/OpenZWave/open-zwave
Zwave-JS-UI also supports the newer Zwave controllers 700 and even 800 etc. But this has already been discussed numerous times.
If you want to stay on OpenZwave stay on Stable 2023.2 or make your own fork and build of Domoticz and keep OpenZwave embedded.
lost
We're not talking about python here... I'm not really competent on C++ but for C, all K&R code snippets would still compile using current gcc with just the right flags.waltervl wrote: Sunday 06 August 2023 13:42 Due to not maintaining the OpenZwave anymore by the Openzwave team would also lead to Domoticz build issues...
That's right there is a replacement, but that's really labyrinthine & for critical home management stuff if you're not sure it will work without issues before start & sure at the end of the day you'll get a working system on current HW that's not really appealing!
