juste made a fresh install of the OS (32bits) and Domoticz on a rpi4.
SONOFF zigbee 3 is not working.
I can't make the Zigbee USB dongle to start correctly with Domoticz.Code: Select all
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian ...
Having this error :
And here is the log from the DZ console :Code: Select all
Transport mode: ZigpyZNP Start Zigpy Transport on ZNP Starting radio znp port: /dev/ttyACM0 ZigpyTransport: thread_processing_and_sending Thread start. Start Web Server connection Web backend for Web User Interface started on port: 9440 Plugin looks to upgrade the Certified Device package Started radio znp port: /dev/ttyACM0 Domoticz Widgets usage is at 1 .2 % (252 units free) Network settings Device IEEE: ff:ff:ff:ff:ff:ff:ff:ff Device NWK: 0xFFFE Network Update Id: 0x0000 PAN ID: 0xFFFE Extended PAN ID: ff:ff:ff:ff:ff:ff:ff:ff Channel: 0 ... Error at startup 'NoneType' object has no attribute 'load_network_info' Coordinator not correctly initializedAny idea of what is the load_network_info and how to make the gateway start ?Code: Select all
0: Object {"Time":"25/07/2023 12:18:22","Module":"TransportZigpy","nwkid":"None","PluginHealth":"Startup","message":"Error at startup 'NoneType' object has no attribute 'load_network_info'","PermitToJoin":{"Duration":0,"Starttime":0},"Thread":"ZigpyCom_2"} 1: Time: "25/07/2023 12:18:22" Module: "Input" nwkid: "None" PluginHealth: "Startup" message: "Coordinator not correctly initialized" PermitToJoin: Object {"Duration":0,"Starttime":0} Thread: "ZigpyForwarder_2" LastLog: 1 StartTime: "25/07/2023 12:18:11" FirmwareVersion: null FirmwareMajorVersion: null PluginVersion: 0: "stable7 - 7 . 1 .001"
Thanks for your help
[SOLVED] Zigbee for Domoticz : object has no attribute 'load_network_info'
urlu75
solved : flashing firmware 6. 10. 3
