Weather - how to build a bolk
marmachine
Domoticz version: 3.4834
Re: Weather - how to build a bolk
Post by marmachine »
marmachine wrote: Wednesday 10 May 2023 12:31
HansieNL wrote: Sunday 07 May 2023 12:30 @marmachine
If you did a git install you can simply change Dashticz' branch to Beta by typing the following command (Terminal) in the Dashticz folder...
Excellent, thanks!
git fetch origin
git checkout beta
M custom_2/CONFIG_DEFAULT.js
M index.html
M index2.html
M jsconfig.json
Branch 'beta' set up to track remote branch 'beta' from 'origin'.
Switched to a new branch 'beta'
git pull
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint: git config pull.rebase false # merge (the default strategy)
hint: git config pull.rebase true # rebase
hint: git config pull.ff only # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
Already up to date.
Is there a way to pull an older branch?
Lokonli
Post by Lokonli »
Most releases have a tag.
With 'git tag' you get a list of all tags.
Via 'git checkout <tag>' you can switch to an earlier release.
MasMat
Domoticz version: 2025.1
Post by MasMat »
marmachine wrote: Sunday 07 May 2023 11:35
api.openweathermap.org/data/3.0/onecall?lat=52.211462&lon=5.972701&appid={API key}
This works (which is the older version)
api.openweathermap.org/data/2.5/weather?lat=52.211462&lon=5.972701&appid={API key}
Does anyone know if the API address can be altered to support the free accounts? Since the only difference is the call address (onecall vs weather)? Add another "provider" to facilitate this?
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
It you try to use 3.0/onecall you'll receive message "Please note that using One Call 3.0 requires a separate subscription to the One Call by Call plan. Learn more here https://openweathermap.org/price. If you have a valid subscription to the One Call by Call plan, but still receive this error, then please see https://openweathermap.org/faq#error401 for more info."
So 3.0 - is only for payment
2.5 - is free (1 000 cals/day), works with recent API keys.
How to get data from any weather provider if answer is JSON i told here
Hope this help you
MasMat
Post by MasMat »
Awesome!
I would like to get the forecast etc working as well so just making calls for current weather seems lacking.
Anything to be done about it?
habahabahaba
MasMat wrote: Wednesday 19 July 2023 13:26
Awesome!
If you read the documentation for API of your provider i think it will not be a problem
I'm using the OWM as one of the providers so can give you an example
api.openweathermap.org/data/2.5/forecast?&lang=us&lat=57.6299&lon=39.8737&appid=<YOUR_API_KEY> - the link
		timer = {'at 06:58 on mon,tue,wed,thu,fri',
		         'at 07:55 on sat',
		         'at 08:55 on sun'
		httpResponses = {'weatherForecastOpenWeather'}
		if (item.isTimer) then
			domoticz.openURL({
				url = 'https://api.openweathermap.org/data/2.5/forecast?&lang=us&lat=57.6299&lon=39.8737&appid=<YOU_API_KEY>',
				method = 'GET',
				callback = 'weatherForecastOpenWeather', -- see httpResponses above.
			}).afterSec(5)
	    if (item.isHTTPResponse) then
	        if (item.ok) then
	            if (item.isJSON) then
	                local jsonParser = require('JSON')
				    local json1 = jsonParser:decode(item.data)
				    local dateTime1 = os.date("%H:%M",json1['list'][1]['dt'])
				    local dateTime2 = os.date("%H:%M",json1['list'][2]['dt'])
				    local dateTime3 = os.date("%H:%M",json1['list'][3]['dt'])
				    local dateTime4 = os.date("%H:%M",json1['list'][4]['dt'])
				    local temp1 = (json1['list'][1]['main']['temp']-273)
				    local temp2 = (json1['list'][2]['main']['temp']-273)
				    local temp3 = (json1['list'][3]['main']['temp']-273)
				    local temp4 = (json1['list'][4]['main']['temp']-273)
				    local pressure1 = (json1['list'][1]['main']['pressure']*0.750064)
				    local pressure2 = (json1['list'][2]['main']['pressure']*0.750064)
				    local pressure3 = (json1['list'][3]['main']['pressure']*0.750064)
				    local pressure4 = (json1['list'][4]['main']['pressure']*0.750064)
				    local humidity1 = (json1['list'][1]['main']['humidity'])
				    local humidity2 = (json1['list'][2]['main']['humidity'])
				    local humidity3 = (json1['list'][3]['main']['humidity'])
				    local humidity4 = (json1['list'][4]['main']['humidity'])
				    local description1 = (json1['list'][1]['weather'][1]['description'])
				    local description2 = (json1['list'][2]['weather'][1]['description'])
				    local description3 = (json1['list'][3]['weather'][1]['description'])
				    local description4 = (json1['list'][4]['weather'][1]['description'])
				    local windSpeed1 = (json1['list'][1]['wind']['speed'])
				    local windSpeed2 = (json1['list'][2]['wind']['speed'])
				    local windSpeed3 = (json1['list'][3]['wind']['speed'])
				    local windSpeed4 = (json1['list'][4]['wind']['speed'])
				    local windGust1 = (json1['list'][1]['wind']['gust'])
				    local windGust2 = (json1['list'][2]['wind']['gust'])
				    local windGust3 = (json1['list'][3]['wind']['gust'])
				    local windGust4 = (json1['list'][4]['wind']['gust'])
                    local str1 = dateTime1..': Temp.: '..math.floor(temp1+0.5)..'°С , press.: '..math.floor(pressure1+0.5)..'mm, hum.: '..humidity1..'%, wind: '..math.floor(windSpeed1+0.5)..'-'..math.floor(windGust1+0.5)..'m/s, '..description1
                    local str2 = dateTime2..': Temp.: '..math.floor(temp2+0.5)..'°С , press.: '..math.floor(pressure1+0.5)..'mm, hum.: '..humidity2..'%, wind: '..math.floor(windSpeed2+0.5)..'-'..math.floor(windGust2+0.5)..'m/s, '..description2
                    local str3 = dateTime3..': Temp.: '..math.floor(temp3+0.5)..'°С , press.: '..math.floor(pressure1+0.5)..'mm, hum.: '..humidity3..'%, wind: '..math.floor(windSpeed3+0.5)..'-'..math.floor(windGust3+0.5)..'m/s, '..description3
                    local str4 = dateTime4..': Temp.: '..math.floor(temp4+0.5)..'°С , press.: '..math.floor(pressure1+0.5)..'mm, hum.: '..humidity4..'%, wind: '..math.floor(windSpeed4+0.5)..'-'..math.floor(windGust4+0.5)..'m/s, '..description4
                    local commStr = 'Weather forecast for nearest 12 hours:'..'\n'..str1..'\n'..str2..'\n'..str3..'\n'..str4
 	                domoticz.executeShellCommand('curl -v -X POST --silent --output /dev/null https://api.telegram.org/<you bot number>/sendMessage -d chat_id=<your chat id> -d text="'..commStr..'"') -- sending notification to telegram
MasMat
Post by MasMat »
If I'm reading this right, this script sends a Telegram msg every morning from Domoticz.
I think we're getting there but how do I move this info to Dashticz to make a weather-block? That's what the original post is dealing with and I didn't want to go off topic.
The default 'weather'-block makes "onecall"s and 'weather_owm' didn't work for me either.
