nil is supposed to be false in conditionals but errors in dzVents
user4563
Domoticz version: 2025.1
Post by user4563 »
In conditionals in Lua I read nil is considered false: https://www.tutorialspoint.com/lua/lua_ ... making.htm
For example if this sensor battery level is nil then this should be false and not fire:
        if domoticz.devices('Garage side door sensor').batteryLevel < 100 then
        -- do something
Instead it errors out:
2023-07-13 19:00:00.304 Error: dzVents: Error: (3.1.8) An error occurred when calling event handler Low battery notification
2023-07-13 19:00:00.304 Error: dzVents: Error: (3.1.8) ...s\dzVents\generated_scripts/Low battery notification.lua:61: attempt to compare nil with number
I did workaround it:
        if domoticz.devices('Garage side door sensor').batteryLevel ~= nil and domoticz.devices('Garage side door sensor').batteryLevel < 100 then
        --do something
I noticed that dzVents / Lua is somewhat lagging Lua itself so I'm not sure if that is the issue?
https://www.lua.org/versions.html#5.4
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
habahabahaba
Domoticz version: 2024.4
Re: nil is supposed to be false in conditionals but errors in dzVents
Post by habahabahaba »
Not all sensors supports .batteryLevel
Have few motion sensors with such problem.
Check documentation on sensor
plugge
Post by plugge »
user4563 wrote: Friday 14 July 2023 2:48 In conditionals in Lua I read nil is considered false: https://www.tutorialspoint.com/lua/lua_ ... making.htm
Wrong assumption: you are not evaluating the sensor battery level, but are comparing nil with a number. That raises -correctly- an error.
Read the Lua manuals and try it yourself in Lua.
There's a diffence between:
1. evaluates correctly
local a = nil
if a then print('ok') else print('not ok') end
and:
2. raises an error
local a = nil
if a < 10 then print('ok') else print(not ok') end
Try it.
user4563
Post by user4563 »
I see what you mean. I assumed nil is false regardless but it's actually only like a boolean false.
Thank you for the information!
boum
Domoticz version: 4.10717
Post by boum »
i don't see your point. it would not work anyway. Neither nil nor false are automagically converted to numbers.
> print( false > 17 )
input:1: attempt to compare number with boolean
user4563
Post by user4563 »
"Lua programming language assumes any combination of Boolean true and non-nil values as true, and if it is either boolean false or nil, then it is assumed as false value. It is to be noted that in Lua, zero will be considered as true."
boum
Post by boum »
Yes. It works only one way. All values are implicitly converted to boolean. Most convert to "true".
But boolean and nil values are not converted to numbers. They cannot be compared to number values without error.
user4563
Post by user4563 »
Thank you everyone for your knowledge!
