Python Plugin: MqttMapper
WBeulink
- Domoticz version: 2024.7
Re: Python Plugin: MqttMapper
- screenshot.1.jpg (182.71 KiB) Viewed 3722 times
RP5 - Bookworm - Domoticz 2025.1 and Latest Beta - Z-Wave JS UI. On Docker
Willem
Willem
Kedi
- Domoticz version: latest
Fill in the type and click on "Aanpassen"
- Xenomes
- Domoticz version: 2026.3
Thanks for this great plugin!!
I used it to connect my Reolink doorbell with three switch/status to Domoticz with the uses of Cam2MQTT
For the used code see:
- Spoiler: show
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.3 (Docker)
Tinytuya
Tinytuya
WBeulink
Thats what I did several times.
But the type and settings don't get saved.
So there is in hardware an item without hardware selection and without any settings.
Thats the problem.
Willem
Willem
Kedi
Did you try to delete the hardware and create it again?
And is the file mqttmapper.json present and valid?
- Xenomes
Sorry to break in, i saw you issue first i mind was a Bullseye or python 3.9.2 issue so i fire up my test system and updated to the latest version of Bullseye and Python and i was correct my test system shows the same problem a empty 'Type:'. I don't have a solution for you yet.
Tinytuya
Tinytuya
- Xenomes
I think you found a bug!
If you put a other plugin in the plugin folder that uses DomoticzEX framework the value of Type: of the Mapper plugin is visible.
So a dirty fix is:
You don't have to use the plugin as you see the plugin works.
Ps. the beta latest build 15372 has also the issue.
So a dirty fix is:
cd ~/domoticz/plugin
git clone https://github.com/stas-demydiuk/domoticz-zigbee2mqtt-plugin.git
sudo systemctl restart domoticz.servicePs. the beta latest build 15372 has also the issue.
Tinytuya
Tinytuya
WBeulink
Thanks for your answer.
The "dirty trick" works!
But when I upgraded Bulseye afterwards the upgrade complete broke Domoticz.
Domoticz can't open port 8080 anymore. Other problem. Not this topic
So I decided to go back to Buster.
Fresh install and complete upgrade.
However i found that I still had to do the "dirty trick" to see hardware type and settings of the plugin.
So: maybe not Bulseye then. Domoticz stable without problems on Buster now.
See attachement:
Also as you see: adding extra folder wit second version of plugin (rename plugin key in plugin.py) adds the possibility to connect to second broker.
Nice!
Hope this will help ..
Willem
See attachement:
Nice!
Willem
- screenshot.3.jpg (183.71 KiB) Viewed 3586 times
Willem
Willem
WBeulink
Question about a "thermostatic setpoint" in Domotic via this plugin.
I managed to create a thermostatic setpoint device in DZ via this plugin.
Correct device and correct reading and display of value of setpoint in DZ.
But I can't figure out how to change the setpoint from DZ.
I get in the logfile: Error: MQTT mapper: No mapping for MQTT mapper - Raam SetPoint heat
Value in DZ doesn't change and nothing send.
I have this in my .json file:
"Raam SetPoint cool": {
"topic": "homeassistant/Raam/67/0/setpoint/11",
"type": "242", "subtype": "1", "switchtype": "0",
"set": {"topic": "homeassistant/Raam/67/0/setpoint/11/set", "payload": {"value":"#"}},
"mapping": {"item": "value"}
I'am on plugin version: version="1.0.12"
Anyone with help on this??
Willem
Willem
- screenshot.4.jpg (182.46 KiB) Viewed 3587 times
Willem
Willem
FlyingDomotic
- Domoticz version: 2020.2
Amazing, as French user was integrating a setPoint device 2 days ago, and find a bug, which is fixed in last version.
Could you please upgrade MqttMqpper and try again?
WBeulink
Just now I found version 1.0.13
Updated friday to 1.0.12
Updated to 13 and it works!
Great.
Willem
Great.
Willem
Willem
Willem
WBeulink
Still playing around with this plugin.
version 1.0.13 Got some created devices working in DZ. But:
Found a problem. Or maybe I'am doing things wrong.
It has to do with a payload in JSON format and using 2 values from that in one device ...
See part of JSON-file
Working:
"Minisensor-1H": {
"topic": "home/OpenMQTTGateway_ESP32_BLE/BTtoMQTT/A4C1384BF6E8",
"type": "81", "subtype": "1", "switchtype": "0",
"mapping": {"item": "hum"}
Working also:
"Minisensor-1T": {
"key": "Minisensor-1T",
"type": "80", "subtype": "5", "switchtype": "0",
"mapping": {"item": "tempc"}
Not working (device is created but never receives any data):
"key": "Minisensor-1TH",
"type": "82", "subtype": "1", "switchtype": "0",
"mapping": {"item": "tempc;hum"}
key's used because it's one topic for all three devices.
That works OK!
Any idea?
Willem
Working:
"Minisensor-1H": {
Working also:
"Minisensor-1T": {
That works OK!
Any idea?
Willem
Willem
Willem
WBeulink
I have to correct. The device icon doesn't show data. But the device log does!
Strange.
Willem
Willem
Willem
Willem
WBeulink
What to do in mapping if the JSON read from the topic is hierachic?
Like this one:
"Time": "2023-07-19T22:10:16",
"AM2301": {
"Temperature": 24.5,
"Humidity": 77.1,
"DewPoint": 20.2
"TempUnit": "C"
Like this one:
"AM2301": {
"Humidity": 77.1,
"DewPoint": 20.2
"TempUnit": "C"
Willem
Willem
FlyingDomotic
Structure you're using is made for merging 2 different MQTT topics in the same Domoticz device.
In your case, all data needed to load Domoticz device is present in the same topic. Could you try:
"Minisensor-1": {
"mapping": {"item": "Temperature;Humidity"}
WBeulink
But the JSON is not flat.
So I need something like:
"mapping": {"item": "AM2301/Temperature;AM2301/Humidity"}
to adress the values properly.
I have this in domoticz log as error:
2023-07-20 00:06:16.904 Error: MQTT mapper: Can't find >Temperature< in >{'Time': '2023-07-19T23:06:16', 'AM2301': {'Temperature': 24.4, 'Humidity': 77.6, 'DewPoint': 20.2}, 'TempUnit': 'C'}<
2023-07-20 00:05:16.953 Error: MQTT mapper: Can't find >Humidity< in >{'Time': '2023-07-19T23:05:16', 'AM2301': {'Temperature': 24.4, 'Humidity': 77.5, 'DewPoint': 20.2}, 'TempUnit': 'C'}<
Willem
Willem
FlyingDomotic
You're right, I didn't saw the AM2301 in the message. Does work?
"mapping": {"item": "AM2301/Temperature;AM2301/Humidity"}-
WBeulink
No. Doesn't work. Alas.
Of cause it's possible to do things like this in Node Red.
But nice thing of this plugin is that maybe we can do things like this without Node Red.
I'am afraid it takes some programming effort to add this functionality.
But maybe .....
Willem
But maybe .....
Willem
Willem
Willem
FlyingDomotic
I made it work with:
Problem was related to the missing ;~0 at end of data.
"Minisensor-1": {
"mapping": {"item": "AM2301/Temperature;AM2301/Humidity;~0"}
WBeulink
Confirm. Works! Thanks.
So ~0 is third item of svalue in DZ?
As expected by this device in DZ?
In that case both of my problems are solved.
Confirmd.
See above .....
Willem
Confirmd.
See above .....
Willem
Willem
Willem
