Custom tab not visible after update to V20231 Topic is solved
Rik60
- Domoticz version: 2025.2
After a update to Domoticz V20231 from V20222 on the main screen the tab 'Custom' is not visible. This tab is for the Domotics Plugins manager and Zigbee plugin. The log shows that the plugins manger and Zigbee are starting, there are no errors, problems. What could be the problem?
keros
Re: Custom tab not visible after update to V20231
Have you check the Custom tab in the user parameters ?
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
Rik60
Ah, that was the trick. Tab is visible now. Thanks
