I've a FIBARO System FGS223 Double Relay installed in the backgarden to control the garden lights. When sending the On/Off command to switch 1 inside the FG223 it always responds, the light always goes on and off. When sending the command to switch 2 in the same FG223 device, I'm not able to switch off the light. Why?
I get the following error message within Domoticz:
2023-06-11 22:25:15.566 Status: HoekHuisZwave: Received timeout notification from HomeID: 4121464633, NodeID: 23 (0x17)
How is this possible> it is literally the same FGS223 devices. Really strange. Somebody experienced the same problem? Is there a solution to this?
FGS223 Double Relay - One On/Off responding the other one not
Re: FGS223 Double Relay - One On/Off responding the other one not
Same experience here, an AEOTEC soft reset solved the issue
