turn a switch of every 10 minus
tjabas
how could in the easiest way make a switch turn off every 10 minutes,
i know that i could set a off delay in the switch parameters, but this function doesnt work anymore, and i dont know why.
so im thinking of another way,
i could set up a timer on the switch, but i will have to make a setting every ten minutes, and i guess that it will take a while since i have to do this on many of my devices.
do you have any idea?
- Domoticz version: 2026.3
Re: turn a switch of every 10 minus
Do it with a s script...
Why is delay off not working? Is it not working for a specific device, for devices of a specific hardware gateway or for all devices?
Last time there was a user that had triggers not working due to a blocked event system due to a incorrect script. So that could be the case.
- habahabahaba
- Domoticz version: 2024.4
Yes, write the script
- Treve
- Domoticz version: v4.11474
I use (daily) a blockly to switch off my iPhone charger after 3 hrs.
Is switch is on, switch off after 180 minutes
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- gizmocuz
Why does the off delay not work anymore? Did you test with a dummy switch as well?
Using it here for a few switches (like a printer, coffee machine) and they are working as they should
tjabas
i think i have found the problem why domoticz doesnt turn off some of the switches anymore,
when i manually turn a switch on using the wall switch, domoticz doesnt see that,i dont know why its like that.
for example, if i turn the lights on in my kitchen using the flicker switch on the wall, it doesnt change the state of the switch in domoticz, thats why domoticz doesnt automatically turn of the same switch since it still "off".
what can i do about that?
Kedi
- Domoticz version: latest
Do you use Wifi and/or 433 Mhz. And how are they connected to Domoticz?
tjabas
No I use zwave
- habahabahaba
