If I try
https://api.openweathermap.org/data/2.5/weather?q=lund,se&APPID=APIKEY Anyone seen this?
https://api.openweathermap.org/data/2.5/weather?q=lund,se&APPID=APIKEY Can you point us to the source of that information?elythomaslumber wrote:This service has ended 1st of April.
Looks 3.0 vs2.5 is not so different. Some info added, but a 3.0 instead of a 2.5 in the url would probably be compatible!kiddigital wrote: Sunday 02 April 2023 17:55 Known issue though is that new API users get an API for OneCall 3.0 while the module uses 2.5 for existing users.
Does it work for coordinates outside Norway? I think I tried this one but did not get any devices showing up...mgugu wrote: Monday 03 April 2023 17:03 "Meteorologisk institutt Norway" plugin seems to be a good alternative to OWM.
True. But if the URL for OWP was configurable looks 2.5 data match 3.0 that looks to be a superset.
By default, devices are not enabled. You have to do it in devices list tab.
