Why my roller shutter scheduled is set to off when I set 0% ? because unfortunately if it is set to off the roller will not open and stay closed. I am forced to set to 1% but the roller shutter is not completely open. I think that's a bug to be corrected.
0% level and off
- jvdz
- Domoticz version: 4.107
Re: 0% level and off
Think you need to start with sharing the roller shutter device details.
thaui
- Domoticz version: 2023.2
The same issue here with Quibino flush shutters. If you chose 0% the pulldown shows off. So if you run your shutters in reversed mode it doesn't work correctly. Because 0% in reversed mode means fully open. I mentioned that in another thread but nobody cares.
- Domoticz version: 2026.3
Please use https://www.domoticz.com/wiki/Blinds for a reference.
