Found many help pages to add the virtual openweathermap plugin, have registered and set data for my town. On the Domoticz weather menu, there is a "Forecast" button upper right, what fetch and show the next days from openwearhermap. So in general yes this work well.
While this put these line into the protocol
2023-04-17 20:08:12.619 Status: OWS: Worker stopped...
2023-04-17 20:08:12.623 Status: OWS: Using specified location (City Bergedorf, DE)!
2023-04-17 20:08:12.945 Status: OWS: City (7290243)-> Lat/Long = 53.4846,10.229
2023-04-17 20:08:12.945 Status: OWS: Updating preferences for forecastscreen to use OpenWeatherMap!
2023-04-17 20:08:12.946 Status: OWS: Started
2023-04-17 20:08:16.271 Error: OWS: Error getting http data!
But aside from several reboot and domoticz restarts, not one device from OWS did appear. Is this some kind of bug in version 2023.1?
Openweather - no devices appear
- Solderbro
- Domoticz version: 2020.1
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
- kiddigital
Re: Openweather - no devices appear
Is ‘enable new devices’ active?
Thorgal789
- Target OS: -
If I m right the actual "openweather" hardware work only with old API key.
If you have register on your site recently, it's normal.
https://github.com/domoticz/domoticz/issues/5336
- Solderbro
Okay understood, the module is broken and only with a payment plan ist will run again. Too bad that also darkweather was assimilated into Apple to squeeze money out of the people. Think the future for Domoticz is to use an own weather station.
- Domoticz version: 2026.3
In latest beta you can use Visual Crossing weather lookup. You can just change the api key and change the hardware gateway and it will take over the weather devices.
https://www.domoticz.com/wiki/Visual_Cr ... her_lookup
There are also other solutions: https://www.domoticz.com/wiki/Weather
- kiddigital
It is not ‘broken’ as it functions perfectly (and free) for everyone that still holds an v2.5 API key.Solderbro wrote:Okay understood, the module is broken and only with a payment plan ist will run again. Too bad that also darkweather was assimilated into Apple to squeeze money out of the people. Think the future for Domoticz is to use an own weather station.
New accounts only get a v3.0 OneCall API key, for which also a ‘freemium’ plan is available (just stay under the 1000 calls per day, which is fine to get updated info every 5 mins).
Problem is that the current module uses 2 different API’s including the previous version of the OneCall API.
So either the old module has to be updated (which forces existing users with a v2.5 API key to get a new key by subscribing to a new plan) or create a second module that supports the updated API’s.
- Solderbro
Thanks for the input,
tryin my luck with the norwegian weather service now. Hope this will not also be eaten up by big business, it deliver values but their webserver deny to show the chart inside from domoticz.
