HI,
I've searched for several examples for timers and tried to create one of my own. Second I'm not a programmer my self, so apologize in front.
What i try to do?
I have created a dummy switch 'Knob1'. As soon as I manually push this button, the timer should activate with a max of 10 minutes.
However whenever I push the switch to on or off I get the following error: "Error: EventSystem: in /users/domoticz/domoticz/dzVents/runtime/dzVents.lua: /users/domoticz/domoticz/dzVents/runtime/EventHelpers.lua:157: attempt to index a boolean value (local 'def')"
I have no idea what causes this error and how to solve it. Anyone who can help me with a solution? Thanks.
Here is the script I have created.
local switchName = 'Knob1' -- dummy switch
local timerName = 'MyTimer'
local timerDuration = 10 -- in minutes
local function startTimer(domoticz, duration)
local endTime = os.time() + (duration * 60)
domoticz.devices(timerName).switchOn()
domoticz.data.timerEnd = endTime
local function stopTimer(domoticz)
domoticz.devices(timerName).switchOff()
domoticz.data.timerEnd = nil
devices = {
switchName
data = {
timerEnd = false
if (device.state == 'On') then
domoticz.log(switchName .. ' is turned on', domoticz.LOG_INFO)
startTimer(domoticz, timerDuration)
elseif (device.state == 'Off') then
domoticz.log(switchName .. ' is turned off', domoticz.LOG_INFO)
stopTimer(domoticz)
end,
onTick = function(domoticz)
if (domoticz.data.timerEnd and os.time() >= domoticz.data.timerEnd) then
stopTimer(domoticz)
Error: EventSystem
Kedi
Re: Error: EventSystem
In data.timerEnd you mix 'boolean' and 'Time' and 'nil'
Beter to use a timestring and work from there.
Thanks. Lets see what I can make of it.
- boum
- Domoticz version: 4.10717
smells like AI generated script (this on tick function popping out of thin air, not existing in sources, forum or wiki…).
To get the wanted behavior, you'll need a timer trigger too. Search in the forum, there are a lot of existing script doing nearly the same thing (amazingly).
