I'm using a Danfoss floor heating controller, CF-MC Master Controller, with some CF-Rx thermostats. I would like to integrate them into Domoticz but did not find any solution. It's an 868.42 MHz system and was wondering if anyone has a solution for this.
Cheers,
Eelco
Danfoss CF2+ thermostate
- Domoticz version: 2024.7
Re: Danfoss CF2+ thermostate
See this discussion on HA (https://community.home-assistant.io/t/z ... /342915/28) you could add a Zigbee module to the controller and have that connected with Zigbee network (Zigbee2MQTT and perhaps Zigbee4Domoticz). Then you can have the devices created in Domoticz and read/control them.
- FireWizard
Hi @eelco
Have a look at: https://github.com/muromec/micropython-danfoss-cf2 and also https://github.com/muromec/rtl_433/blob ... nfoss_cf.c
This has been made for Home Assistant, so probably the same as @waltervl link.
Regards,
Herman
Regards,
Herman
