I only had to change the website name from https://recycleapp.be/ to https://www.recycleapp.be/ to make it work again.
Maybe you could try the same in the Dashticz module?
Thanks!jvdz wrote: ↑Saturday 08 April 2023 17:38 I can confirm that things changed as my test setup also fails for this website: recycleapp.be with error:301 Moved Permanently
You could try to use the Afvalinfo option within Dashticz, check if your region is available through this api: https://github.com/heyajohnny/afvalinfo ... er/Versionmadpatrick wrote: ↑Wednesday 28 February 2024 19:35 Does anybody expriencing some connection or update problems with afvalwijzer.nl ?
Since a few days i don't get any proper updates anymore.
2024-04-24 14:00:00.080 Status: LUA: 14:00:00 MainScript: #!# Warning: These records are missing in your garbagecalendarconfig.lua file, so no notifications will be send!
2024-04-24 14:00:00.080 Status: LUA: 14:00:00 MainScript: #!# -- start -- Add these records into the garbagetype_cfg table and adapt the schedule and text info to your needs :
2024-04-24 14:00:00.080 Status: LUA: ["restafval- mini containers"] ={hour=19,min=02,daysbefore=1,reminder=0,text="restafval- mini containers"},
2024-04-24 14:00:00.080 ["papier en karton."] ={hour=19,min=02,daysbefore=1,reminder=0,text="papier en karton."},
2024-04-24 14:00:00.080 Status: LUA: 14:00:00 MainScript: ==> found schedule:restafval- mini containers: 26 apr ; GFT Bak: 3 mei ; PMD Zak: 3 mei ;
Pretty sure you are in the wrong thread here!
Request URL:
http://192.168.1.8/dashticz/vendor/dashticz/garbage/index.php?service=recycleapp&street=xxx&sub=xxx&zipcode=xxx&nr=xx&t=
Request Method:
GET
Status Code:
500 Internal Server Error
Remote Address:
192.168.1.8:80
Referrer Policy:
strict-origin-when-cross-origin
jQuery.Deferred exception: Cannot read properties of undefined (reading '0') TypeError: Cannot read properties of undefined (reading '0')
