I've just migrated my domoticz installation from OZW to Zwave-JS-UI with MQTT Auto Discovery,
which is working fine and much more stable than OWZ.
On the Developer's Website I found this statement:
"The preferred method of integrating your Z-Wave components with Home Assistant is through the official Home Assistant Z-Wave JS integration, this because MQTT Discovery is limited compared to a native integration and Home Assistant updates frequently break it. Based on this I would NOT RECOMMEND using MQTT Discovery, I don't plan to keep it maintained in the future."
Does this mean this new Z-Wave-Integration Method for Domoticz is already abandoned by the developer ?
MQTT Discovery not maintained in future
- cbartetzko
- Domoticz version: 2023.1
lost
Re: MQTT Discovery not maintained in future
Well... another zwave transition headache in sight if the only feature that helped a bit on this bumpy zwavejs road ends. But with so many devices with tricky bugs managed from their conf files in OZW in the past issues were IMO expected.
JuanUil
- Domoticz version: 4.11083
may hope that this is not true
- heggink
- Domoticz version: 12451
There are a number of talks on this on the forum already as well as in the slack channel. This is a statement that was made quite a while ago. My personal view is as follows:
Your situation may be different but switching to zwavejs2mqtt has been a blessing where OZW was a constant hassle and nightmare.
- he is indicating that he is looking to "not maintain" in the "future", that is not the same as to completely desupport
- that means that new stuff may not come "at some point in the future" until someone steps up and maintains that bit (hint hint)
- as long as you don't upgrade into a release that won't support your devices, you have no issue.
if ever this becvomes an issue, we could consider adding 'native' instad of HA autodiscovery support to domoticz.
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
lost
That's for now my point with OZW, as I'm quite happy with it... Anyway, I don't buy new zwave hardware until some alternative open source support convince me to do so. And zwavejs never did: Bad integration, bad language choice... and now bad discovery layer over it.heggink wrote: Thursday 30 March 2023 18:58
Fishwaldo, come back, zwave for DIY is dying without you!
akamming
still have to do the zwave migration. Haven't done it cause i have quite a few devices and OZW is very stable for me. So i don't recognize the "nightmare". Maybe i'm lucky.heggink wrote: Thursday 30 March 2023 18:58 if ever this becvomes an issue, we could consider adding 'native' instad of HA autodiscovery support to domoticz.[/list]
I am very happy with the autodiscovery. It is a great addition to Domoticz and good to know your are already thinking on the alternative. Just thinking: Is there some way you can think about migrating all ZWAVE devices at once? (also to autodiscovery?)
I did try to migrate a few times, but find out is quite a lot of work, so that's keeping me on OZW until i have to change. And i am a bit worried knowing i have to do that again in the near future..
