JSON - getting data from an HTTP-response
peterbos
Post by peterbos »
If I do a call to
https://apps.hvcgroep.nl/rest/adressen/1562BP-1
I get this response:
[{"bagId":"0479200000033698","postcode":"1562BP","huisnummer":1,"huisletter":"","huisnummerToevoeging":"","openbareRuimteNaam":"Glennstraat","woonplaatsNaam":"Krommenie","latitude":52.50839,"longitude":4.755153,"woonplaatsId":1880,"gemeenteId":479}]
I searched the forum and the rest of the internet but can't find how to retrieve the values of the fields as strings (frankly, I miss a manual how to use json in dzVents). Can someone point me in the right direction?
Peter
roblom
Re: JSON - getting data from an HTTP-response
Post by roblom »
Not a direct answer to your question, but there is a plugin you can use for that.
https://github.com/Xorfor/Domoticz-Afvalwijzer-Plugin
Domoticz version: 2025.1
And there is also a garbage calender lua script for almost the whole netherlands: https://github.com/jvanderzande/GarbageCalendar
For example scripts with json search for keyword "isJSON" in this forum: search.php?keywords=isjson
The parsing of json depends on its structure. As dzvents is lua you can also search outside this forum for lua and json.
rwblinn
Domoticz version: 4
Post by rwblinn »
Please find a dzVents example triggered by a switch (hardware dummy virtual sensor):
-- Domoticz IDX of the switch triggering HTTP request
local IDX_SWITCH  = 16
local URL_SERVER = "https://apps.hvcgroep.nl/rest/adressen/1562BP-1"
local RES_HTTP = "RES_1562BP"
local LOG_MARKER = "LOG_1562BP"
           devices = { IDX_SWITCH },
           httpResponses = { RES_HTTP }
	logging = {
	  level = domoticz.LOG_INFO, marker = LOG_MARKER,
           if (item.isDevice) then
             domoticz.openURL({ url = URL_SERVER, method = 'GET', callback = RES_HTTP, })
          if (item.isHTTPResponse) then
            if (item.statusCode == 200) then
                if (item.isJSON) then
                   -- Get the data which is a JSON array with one element
                    local data = item.json[1]
                    domoticz.log(string.format('lon=%s, lat=%s', tostring(data["longitude"]), tostring(data["latitude"])))
                    -- lon=4.755153, lat=52.50839. Instead data["key"] can also use data.key:
                    -- domoticz.log(string.format('lon=%s, lat=%s', tostring(data.longitude), tostring(data.latitude)))
                -- Error like 7 false; ERROR 7:Couldn't connect to server
                domoticz.log(string.format("ERROR %d:%s", item.statusCode, item.statusText))
willemd
Domoticz version: 2024.1
Post by willemd »
If you create a new DZvents script and choose the template for http request, you can then fill in your api call and modify the assignment of someValue slightly and you will get the example below.
I guess your problem was how to get a certain value out of the long string and I have included in the example the extraction of the postal code. Documentation on this is indeed very poor and in previous scripts I developed I have spent days of trial and error.
In this case the following works:
local someValue = item.json[1].postcode
The important thing is to look closely to the buildup of your response, i.e. the square brackets, the curled brackets, the field identifiers etc.
		timer = {
			'every 1 minutes' -- just an example to trigger the request
		httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
	logging = {
		marker = 'template',
		if (item.isTimer) then
			domoticz.openURL({
				url = 'https://apps.hvcgroep.nl/rest/adressen/1562BP-1',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
			if (item.ok) then
					local someValue = item.json[1].postcode -- just an example
					-- update some device in Domoticz
					domoticz.log('myTextDevice '.. someValue, domoticz.LOG_INFO)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
peterbos
Post by peterbos »
Thanks all,
It was the [1] that did the trick. That is not in the template for a http request.
Peter
willemd
Post by willemd »
Also note there is no dot before the [1]
basically you use a number between brackets, without a dot, in order to get the part between curly brackets
and you use the name, with a dot before it, of a name/value pair to get the value
and this can be nested in many ways
Once you get that logic is becomes easy ...
