turns on a switch every time the air sensor value is 12
betogar
Post by betogar »
I want to make a script that turns on a switch every time the air sensor value is 12 or higher and turns off when it is 11 or less
I am using a custom sensor for air quality
try this but it gives error
-- Define the name of the custom sensor and the name of the switch
local AQI_sensor_name = "AQI"
local power_switch_name = "power"
-- Function to turn on the switch
function turn_on()
  commandArray[power_switch_name] = 'On'
  print("Turning on " .. power_switch_name)
-- Function to turn off the switch
function turn_off()
  commandArray[power_switch_name] = 'Off'
  print("Turning off " .. power_switch_name)
-- Function to check if the switch is already on or off
function checkFirst()
  local AQI_value = tonumber(otherdevices[AQI_sensor_name])
  if AQI_value >= 12 and otherdevices[power_switch_name] == 'Off' then
    turn_on()
  elseif AQI_value <= 11 and otherdevices[power_switch_name] == 'On' then
    turn_off()
-- Execute checkFirst on every update of the custom sensor
    devices = {
      AQI_sensor_name
  execute = function(dz, trigger)
    checkFirst()
Captura de pantalla 2023-03-18 120316.png (7.07 KiB) Viewed 1705 times
habahabahaba
Domoticz version: 2024.4
Re: turns on a switch every time the air sensor value is 12
Post by habahabahaba »
try this (remove spaces. sorry, i don't how to insert normal code - it gives me mistakes):
    devices = {
      {'your_sensor_name'},
    execute = function(dz)
    	     local AQI = dz . devices(IDx) -- Idx - id of your AQI sensor
     local powerSwitch = dz . devices(IDx) -- Idx id of your power switch
     if AQI . value >=12 then
         powerSwitch . switchOn() . checkFirst()
        powerSwitch . switchOff() . checkFirst()
betogar
Post by betogar »
try with value 1, it doesn't work
nothing in log
    devices = {
      {'AQI'},
    local AQI = dz.devices(126) -- Idx - id of your AQI sensor
     local powerSwitch = dz.devices(139) -- Idx id of your power switch
     if AQI.value >=1 then
         powerSwitch.switchOn().checkFirst()
        powerSwitch.switchOff().checkFirst()
habahabahaba
Log?
habahabahaba
OK. try this one. Working code - just tested.
And here is FAQ of DzVents.
		timer = { 'every minute',
	execute = function(domoticz , timer)
		local AQI = domoticz  .devices(40)
		local switchBackyard = domoticz . devices(1)
	    AQI . updateCustomSensor(11)  --just an example to set the value
		if (AQI . sensorValue >= 12 ) then
	        switchBackyard . switchOn() . checkFirst()
	       switchBackyard . switchOff() . checkFirst()
        domoticz . log(tostring(AQI . sensorValue)..' - AQI value', domoticz . LOG_ERROR)
betogar
Post by betogar »
It works but I see an error in the log, any ideas?
		local AQI = domoticz.devices(126)
		local Power = domoticz.devices(139)
		if (AQI.sensorValue >= 1 ) then
	        Power.switchOn().checkFirst()
	       Power.switchOff().checkFirst()
        domoticz.log(tostring(AQI.sensorValue)..' - AQI value', domoticz.LOG_ERROR)
Domoticz version: 2026.3
That is because you log it as an Error:
should be
domoticz.log(tostring(AQI.sensorValue)..' - AQI value', domoticz.LOG_INFO)
betogar
Post by betogar »
it works! thanks guys!
BerryB
Post by BerryB »
I tried the script but it gives an error: attempt to compare number with nil
What am I doing wrong here? Thanks in advance.
Ps. trying to figure out how to paste my code beneath.
BerryB wrote: Thursday 01 June 2023 8:50 I tried the script but it gives an error: attempt to compare number with nil
Some device value probably wrong in your script. But it is important to know in what line of your script the error occurs.
To post code, just copy paste and put it between code tags.
app.php/help/bbcode
BerryB
Post by BerryB »
waltervl wrote: Thursday 01 June 2023 10:00
.php/help/bbcode
When I try to copy & paste the code between code tags I get this message:
You can’t post image, email or url links that are external to this domain. Please remove domoticz., domoticz., Tempsensor., Power., Power., domoticz., Tempsensor. and domoticz.
Thanks for the help
Probably because you are a new user. Are there urls in the code?
BerryB
Post by BerryB »
waltervl wrote: Thursday 01 June 2023 23:58 Probably because you are a new user. Are there urls in the code?
No there are no URL's.
I think I am this close solving the problem.
Maybe I'm not giving the temp sensor a "start temp"?
####.updateTemperature(11)
error is : attempt to compare nil with number
The ### is in my script the name of the device defined in local. But cant post because "they are external"
BerryB
Post by BerryB »
I think I solved it. Don't know exactly if I did the repeat every minute ok?
local switchDeviceID = 135  -- Vervang 123 door het werkelijke apparaat-ID van de schakelaar
    timer = {
      'every minute'
        devices = {
            'SonofGTemperatuur'  -- Vervang 'temperatuursensor' door het werkelijke apparaat-ID van de temperatuursensor
    execute = function(domoticz,device)
        local temperatureThreshold = 16
        if device.temperature <= temperatureThreshold then
            domoticz.devices(switchDeviceID).switchOn()
            domoticz.log("Temperatuur boven de " .. temperatureThreshold .. " graden. Schakelaar is geactiveerd.")
            domoticz.devices(switchDeviceID).switchOff()
            domoticz.log("Temperatuur onder de " .. temperatureThreshold .. " graden. Schakelaar is gedeactiveerd.")
The 'every minute' part should be removed as it will mix up the device setup:
in 'execute = function(domoticz,device)' the device parameter is filled with the triggered device. When execute is triggered by the timer, device is a timer object and the declaration of device.temperature will fail as a timer has no temperature and giving nil.
BerryB
Post by BerryB »
waltervl wrote: Friday 02 June 2023 11:34 The 'every minute' part should be removed as it will mix up the device setup:
Thanks 4 the help.
