Since I've updated to build 15141 I get this error message. I understand that it has something to do with my heatbooster but I know the Domoticz support (autodiscovery) isn't supported. Someone know who can solve this error?
Error: Value is not convertible to double.! (topic: homeassistant/number/Heatbooster-Hal/ambientcontrol-temp/config/message: {"name":"Room temperature target","unique_id":"Heatbooster-Hal_ambientcontrol-temp","object_id":"Heatbooster-Hal_ambientcontrol-temp","icon":"mdi:home-thermometer","state_topic":"Heatbooster-Hal/ambientcontrol-temp","unit_of_measurement":"°C","command_topic":"Heatbooster-Hal/ambientcontrol-temp-ref","min":14,"max":26,"step":"0.50","device":{"name":"HeatBooster - Heatbooster-Hal","model":"HeatBooster","manufacturer":"SDR Engineering","identifiers":"Heatbooster-Hal","sw_version":"2.1.8","configuration_url":"http://192.168.178.11/"}}
Value is not convertible to double Topic is solved
lwolf
Re: Value is not convertible to double
Do you know the payloads which arrives to ambientcontrol-temp?
I am using this template for my thermostat with Domoticz and ESPEasy-like generic MQTT: ( #/state contains the current state, #/set used to set value)
My payloads are simple numbers with one decimal.
homeassistant/climate/thermostat1/config
{"unique_id": "HV_1","name": "thermostat4_setpoint","qos": 1,"retain": true,"~":"thermostat1/thermo1","temperature_command_topic": "~/Setpoint/set","temperature_state_topic": "~/Setpoint/state","temperature_unit": "C","precision": 0.1,"temp_step": 0.5,"max_temp": 40,"min_temp": 10}'
- gizmocuz
This issue was caused by the 'step' value, it was not a number but a string.
As roblom uses a specific SDR device (not zigbee/zwave) the request to solve this upstream has been asked as well
Anyway, in the current beta version this is solved as well
roblom
Can confirm SDR Engineering is going to correct it also.
Lightning fast
thanks for your help!
Lightning fast
