NilsNijenhuis wrote: Saturday 02 April 2022 14:58
Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
couple of days ago it still worked and i haven't changed anything?!
Fixed in latest Dashticz beta.
Can you test?
Thank you for your excellent service! Very much appreciated!
Are you planning to create a new masterbranch shortly... i assume i cannot simply swop my master into beta in order to fix the issue with Circulus garbage, can i?
Can you test?
You can simply change Dashticz' branch to Beta by typing the following command in to the Terminal:
>> D custom/CONFIG_DEFAULT.js
>> Branch 'beta' set up to track remote branch 'beta' from 'origin'.
>> Switched to a new branch 'beta'
git pull
>> Already up to date.
After reboot there doesn't seem to be any difference which is good basically, however i was hoping to see the garbage calendar back to life again...
It now presents: "geen gegevens gevonden"
marmachine wrote: Wednesday 25 May 2022 10:26
Okay, so i did:
git fetch origin
git checkout beta
git pull
>> Already up to date.
circulusberkel is working on my system.
Maybe something on your system (CORS proxy, ssl issues), or, related to your zipcode.
Can you send me your zipcode and housenumber via PM, then I'll check.
oranjeboven495 wrote: Wednesday 13 July 2022 9:56
Did you get Circulus to work? I'm still not getting any data. Do you need to add the icalurl to the parameters?
Unfortunately some Circulus zipcodes don't work at the moment, because of an API change at their side.
I had a look, but fixing it needs some more investigation.
I'm busting my brains to get this nice module working..
1. I'm in GAD area, but this company entry does not work. URL should be inzamelkalender gad nl / adres/postalcode:housenumber but it does not seem to sent a rest response, but a website.
2. Therefore I tried the ical option (inzamelkalender gad nl/ical/0406200000067948), but this throws script errors:
j Q u er y .Deferred exception: Cannot read properties of undefined (reading 'length') TypeError: Cannot read properties of undefined (reading 'length')
Could you point me in the direction on how to fix this?
Renber wrote: Wednesday 05 April 2023 8:17
Good morning,
I no longer receive information with Recycleapp, do you know what is happening?
THANKS
werkt bij mij ook niet meer. Ik vemoed dat de toegang tot de api niet meer werkt. Ik heb nu gewoon de agenda van de recycleapp gekopieerd naar mijn persoonlijke agenda die ook zichtbaar is in dashticz.
