Running a RFXtrx433E want a working temp sensor
taw6
Post by taw6 »
Hi All,
I am Running a USB RFXtrx433E with
Firmware version = 1028
Firmware Type = Ext
Connected to Domoticz 2023
I brought a Bresser temp/hydro sensor from amazon netherlands(ART No 7000993) and unable to see it in Domoticz or with rfxman, meanwhile my remote blind controls work fine. I have enabled both FineOffset and FineOffset.
I check the latest RFXtrx User Guide, it looks like it is not supported on the RFXtrx433E.
I tried some different firmware but nothing seems to work.
Any advice on which temp/hydo sensors will work with a USB RFXtrx433E and which firmware to use?
Cheers
Tim
solarboy
Domoticz version: 2024.6
Re: Running a RFXtrx433E want a working temp sensor
Post by solarboy »
I bought a bunch of these and they worked well.
https://www.aliexpress.com/item/3288128 ... 18020D6Woz
RedEarth
Post by RedEarth »
I have firmware Pro2/1044 and I have Oregon Scientific THGR800 (temp and humidity) and also an older Oregon temp-only sensor (not sure of the model number but Domoticz shows it as "THR128/138, THC138"). Both work nicely.
taw6
Post by taw6 »
I ordered three of the aliexpress ones on the link you mentioned. Can you confirm the firmware version you are running on the RFXtrx433E?
solarboy
Post by solarboy »
taw6 wrote: Tuesday 21 February 2023 22:31 I ordered three of the aliexpress ones on the link you mentioned. Can you confirm the firmware version you are running on the RFXtrx433E?
Version Pro2 / 1043
solarboy
Post by solarboy »
They appear as "Alecto WS1700"
taw6
Post by taw6 »
Installed pro2/1043 waiting for the temp sensors to turn up
rylfas
Domoticz version: 2024.7
Post by rylfas »
