Dashticz v3.10.2 beta
Lokonli
Post by Lokonli »
New Dashticz release.
Main changes:
  • Dials: For P1 and Energy dials you can choose to show the daily energy counter or the actual power usage via the subtype block parameter. You can combine it with the 'inverted' block parameter to choose the plus-minus definition.
  • Graph: New filter option 'todaytomorrow' to show data for today and tomorrow only
See the following link for all changes: v3.10.2
madpatrick
Domoticz version: 2026.1
Re: Dashticz v3.10.2 beta
Post by madpatrick »
Great !!
Is it possible to have thxt under a dimmer like with the other switches ?
2023-02-19 09_58_19-Fully Remote Admin.png (83 KiB) Viewed 606 times
EdwinK
Post by EdwinK »
Great. :)
Lokonli
Post by Lokonli »
madpatrick wrote: Sunday 19 February 2023 9:59 Great !!
You mean to have the title of the block below the block, like for instance your Tuin and Kamer example?
How did you create it in your example?
madpatrick
Correct.
I'v this added to the configuration
custom.js
// TITLE BLOCKS
blocks['Title_Lichtschakelaars']= {width: 12,type: 'blocktitle',title: 'Schakelaars',image : 'switch-on.png'}
blocks['Title_Garbage']		= {width: 12,type: 'blocktitle',title: 'Afval',image : 'garbage.png'}
blocks['Title_Tuin'] 		= {width: 2, type: 'blocktitle',title: 'Tuin'}
blocks['Title_Woonkamer'] 	= {width: 2, type: 'blocktitle',title: 'Woonkamer'}
blocks['Title_Hal'] 		= {width: 2, type: 'blocktitle',title: 'Hal'}
blocks['Title_Ventilatie'] 	= {width: 2, type: 'blocktitle',title: 'Ventilatie'}
blocks['Title_Screens'] 	= {width: 2, type: 'blocktitle',title: 'Screens'}
blocks['Title_Muziek'] 		= {width: 2, type: 'blocktitle',title: 'Muziek'}
custom.css
/* ---------------  Text below Dial ---------------  */
div[data-id*="gr_tuin"] span[class*="device"],
div[data-id*="gr_kamer"] span[class*="device"],
div[data-id*="dimmer_hal"] span[class*="device"],
div[data-id*="ventilatie"] span[class*="device"],
div[data-id*="Slide_1"] span[class*="device"],
div[data-id*="Slide_2"] span[class*="device"]		{font-weight: bold; color:yellow !important;position: fixed;font-size: 20px;top: 130px;width: 140px;}
