Can this native hardware type still be used? I miss a howto, but maybe I didn't search properly. I can't get it working.
Thanks in advance
Goodwe solar inverter via Web API
Jan Jansen
- Domoticz version: Stable
- Domoticz version: 2026.3
Re: Goodwe solar inverter via Web API
Currently it does not work, that is why python plugins are being created
https://github.com/domoticz/domoticz/issues/5393
Jan Jansen
@waltervl
Thanks for your reply. Too bad the native hardware doesn't work anymore.
Regards!
Regards!
willemd
If this is a traditional central inverter for solar panels and you can't get data directly from the inverter, you could as an alternative still install a kWh meter on the AC power line and measure the total solar panel output in that way. That is what I do. I use the homewizard wifi kwh meter. (Originally I had the plugwise connector but that stopped working)
The python plugins for the goodwe inverters are functional so you can use one of those (one for web and one for modbus) see https://www.domoticz.com/wiki/Plugins
- gizmocuz
Or maybe someone can update the c++ code?
