Debian 11 install Domoticz 2022.2 no python loaded
tonbor
Post by tonbor »
Installed Domoticz 2022.2 fresh at Debian 11 NUC. No python loaded by Domoticz. Python is installed version 3.9, see picture. Any suggestions?
About Domoticz
Version: 2022.2
Build Hash: eea9db734
Compile Date: 2022-11-05 13:05:35
dzVents Version: 3.1.8
Python Version: None
Sjonnie2017
Domoticz version: Latest ß
Re: Debian 11 install Domoticz 2022.2 no python loaded
Post by Sjonnie2017 »
You need more than just the libs. Have you installed PYthon3?
YouLess Energy meter
Domoticz version: 2026.3
tonbor
Post by tonbor »
Sjonnie2017 wrote: Wednesday 01 February 2023 11:49 You need more than just the libs. Have you installed PYthon3?
rob@NUC5-Rob:~$ python3 -V
Python 3.9.2
rob@NUC5-Rob:~$ dpkg --get-selections | grep libpython
libpython3-stdlib:amd64 install
libpython3.9:amd64 install
libpython3.9-minimal:amd64 install
libpython3.9-stdlib:amd64 install
rob@NUC5-Rob:~$
Sjonnie2017
The wiki says:
If you still do not see the python version in Domoticz menu Setup - About Domoticz please install python3-dev:
sudo apt install python3-dev
Restart Domoticz.
Have you tried that?
tonbor
Post by tonbor »
Yes, still no python in the about of Domoticz, but ..... python is present and working.
While starting Domoticz it will normally log some info on Python. Are there some clues to see?
sieth
Post by sieth »
I had to do this for it to work:
wget http://nz2.archive.ubuntu.com/ubuntu/po ... _amd64.deb
sudo dpkg -i *.deb
Maybe, it will work for you as well.
