SLWF-01pro Midea Wi-Fi Module Topic is solved
ssk17051980
- Domoticz version: 2023.2
Re: SLWF-01pro Midea Wi-Fi Module
the picture with the USB adapter is inside my AC. I think that inside that USB adapter is the SLWF-01pro stick model, because my AC unit work in Home Assistant whit midea integration.
BarryT
- Domoticz version: 2024.3
I mean your heatpump devicessk17051980 wrote: Wednesday 01 February 2023 20:55 the picture with the USB adapter is inside my AC. I think that inside that USB adapter is the SLWF-01pro stick model, because my AC unit work in Home Assistant whit midea integration.
ssk17051980
Nordstar.
But the pic from this page it's the same whit mine.
BarryT
Okay, it looks like nordstar is an oem midea so it will work
ssk17051980
can you gave-me the entire DIY, thx
BarryT
When i have time (this weekend) i will write an little tutorial.
ssk17051980
BarryT
Okay, here is the little tutorial:
I'm using a Odroid with Linux and HomeAssistant, but you can use an VM or raspberry as well.
(We just need just HomeAssistant for compling the firmware)
First start with HomeAssistant and install ESPHome over there.
After you installed ESPHome, add a new device >
Call it Airco (for example) and click next > After that choose the esp8266 board > Then skip the key (since we do not need it because no homeassistant is using)
BarryT
Great, your first device is made.. >
Then click on edit: >
After that use this YAML and make changes to your own settings.:
DO NOT forget to:
make your own unique name and so change the roomairco to the name of your device.
also do not forget to setup the mqtt broker to the ip or hostname of your mqtt broker, otherwise it will not work
esphome:
name: roomairco # Give your device a main-name
platform: ESP8266
board: esp12e
wifi:
ssid: SSID
password: SSIDPASSWORD
# Enable fallback hotspot in case wifi connection fails
ap:
ssid: roomairco
captive_portal:
# Enable logging
logger:
baud_rate: 0
sensor:
- platform: wifi_signal # Reports the WiFi signal of your device
name: roomairco wifi dB"
update_interval: 30s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "roomairco wifi quality"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
mqtt:
broker: yourlocalmqttbroker.lan # You can use hostname or IP
keepalive: 60s
discovery: true
discovery_retain: true
discovery_prefix: homeassistant
birth_message:
topic: roomairco/status
payload: online
will_message:
payload: offline
ota:
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
climate:
- platform: midea
name: roomairco # Use a unique name.
period: 1s # Optional
timeout: 1s # Optional
num_attempts: 1 # Optional
autoconf: true # Autoconfigure most options.
beeper: true # Beep on commands.
visual: # Optional. Example of visual settings override.
min_temperature: 17 °C # min: 17
max_temperature: 30 °C # max: 30
temperature_step: 1 °C # min: 1
supported_modes: # All capabilities in this section detected by autoconf.
- FAN_ONLY # This capability is always used.
- HEAT_COOL
- COOL
- HEAT
- DRY
custom_fan_modes:
- SILENT
- TURBO
supported_presets: # All capabilities in this section detected by autoconf.
- ECO
- BOOST
- SLEEP # This capability is always used.
custom_presets: # All capabilities in this section detected by autoconf.
- FREEZE_PROTECTION
supported_swing_modes:
- VERTICAL # This capability is always used.
- HORIZONTAL
- BOTH
outdoor_temperature: # Optional. Outdoor temperature sensor (may display incorrect values after long inactivity).
name: roomairco buitentemperatuur
web_server:
port: 80 # Wich port to use the interface in your browsermake your own unique name and so change the roomairco to the name of your device.
BarryT
Then we going to compile the code into firmware by doing save > install > manual download > modern format:
BarryT
After compiling you will get the .bin file to upload to the usb-stick you did recieve. >
Put in the usb-device into an USB-Port or the usb into your HVAC device itself, and go to your wi-fi list
after some 20/30 seconds you will see an open ssid network with openesp, connect to it.
then you be asked to connect the usb-device to your network
then connect the usb-device to your wi-fi network then it will get an ip address to connect to.
search the ipaddress of your usb-device on your network and open it in your browser
(example: http://192.168.1.50/) and upload the firmware you just made to your usb-device: >
After that, go into your Domoticz and add new hardware (if not done already) > MQTT AutoDiscover
Domoticz does search for all HomeAssistant MQTT devices and will add them automatically.
When everything is finished, your device should appear in to Domoticz after MQTT AutoDiscover finished his job..
Happy automation
Happy automation
BarryT
Some other pictures of the project >
O-Droid (to compile on HA): The USB-Device : Questions? Feel free to ask..
Nice sunday!
Nice sunday!
ssk17051980
Thank you for the effort.
I hope that this week my wife will relieve me of the household chores and I will follow the tutorial.
BarryT
No problem, g'luck!ssk17051980 wrote: Monday 06 February 2023 20:28 Thank you for the effort.
