Hello, does anyone have a tip for a zigbee temperature/humidity sensor with a display that would send data when it changes by 0,1 instead of 0,5 degrees?
Thank you
Temperature senzor
- Domoticz version: 2026.3
Re: Temperature senzor
I use the SONOFF SNZB-02 ZigBee Mini temperature/humidity sensor and it is reporting 0,1 delta's
Edit: without display....
jval
And can you set some event by 0,1 change. I have some Xiaomi and Aqara senzors which show with a sensitivity of 0,1, but the change is sent to the gateway only if the change is at least 0,5. Maybe to save battery.
Can you test if change 0,1 execute device trigger?
https://www.domoticz.com/wiki/DzVents:_ ... ce_changes
Thank you.
Thank you.
I see in my graphs deltas of 0.1 degrees so it will report those small. a Hue Motion (with temperature) will send the value every 5 minutes, also with delta of 0,1 degrees.
jval
OK, thank you. I will try to order SNZB-2D.
