DS18B20 dropping from domiticz
njlammerts
- Domoticz version: 2022.2
I have overcome the problem of DS18B20 and recognition by last address decimal. I ordered several DS18B20's by different sellers, so I have now 6 sensors that are recognized as separate sensors. Now I have the problem that sensors are dropping out of raspberry. With the command:
cat /sys/bus/w1/devices/w1_bus_master1/w1_master_slave_count
I get the reply how much sensors are detected. After 2-48 hours of hard reset (power off) the reply is always less then 6. Sometimes it is 6 but after some time the sensors are dropping and are not recognized anymore. This means that the directory's are not present.
In below graph it shows that sensor stops working on Friday at 20:10 and spikes up after restart raspberry on Saturday at 12:xx
Only CV retour and Boiler Middle kept working over this period
I have read something about counterfeit/fake sensors, but also about a piece of 1wire software that is not working correct in the newest version. Does anyone recognizes this and has found a solution?
willemd
- Domoticz version: 2026.3
Re: DS18B20 dropping from domiticz
I am using 2 sensors without problems.
How is your wiring? Could this be a reason for them dropping out?
BartSr
- Domoticz version: V2024.7
I m using lots of DS18B20 sensors. All from Ali.
These are hooked up to ESP8266 with EspEasy.
Never had a sensor dropped.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
njlammerts
Can you connect multiple DS18B20 to one ESP8266, or does every DS18B20 needs its own ESP8266?BartSr wrote: Sunday 29 January 2023 17:40 I m using lots of DS18B20 sensors. All from Ali.
njlammerts
I have all DS18B20 connected to a piece of experiment print and from there i have about 40cm cable to the Pi. The pull-up resistor is also on the experiment board. All the wires from the experiment board are +- 1m longwillemd wrote: Saturday 28 January 2023 18:35 I am using 2 sensors without problems.
Strange thing is that the sensors stay working somtimes for 1-2 days and sometimes drop after 1 hour.
To get the sensors back, i have to turn power off/on the raspberry and sometimes 1 or to are missing also and an other power/off/on is needed.
willemd
I am not on expert on electronics, but with that kind of unpredictable behaviour I would expect a hardware issue rather than software, such as maybe power below/above a certain threshold switching the sensors off. I would experiment with different setups, starting with a different power supply. Then, are the sensors connected to the 5V pin or 3.3V pins?
njlammerts
I have a degree in Electronics an can say that power is not the problem.
The problem is with both 3.3 an 5V power from the GPIO 1 and 2 pin. I use the original power supply that came with the Raspberry.
Also the sensors seem to drop at random. The 2 that are working now, may not be working tomorrow.
So its not a power problem
njlammerts
When the Pi is booted there are 6 directory's for 6 sensors, each wit the name of the specific 1-wire ID.
In this directory are lots of other files and dir's.
When the sensors are dropped, the specific directory's are also gone, so that's why there is no temperature info.
This is probably a RPi or cabling issue.
Check internet, I came across this topic: https://forums.raspberrypi.com/viewtopic.php?t=25154
njlammerts
I am running stable now for 6-9 months now. The problem is/are not original DS18B20 sensors. I bought some from Amazone.nl and AlieXpress and they are not to be trusted. I have a different source of sensors and that goes well!!
I now have about 6-7 running on 1 PiZero and works fine.
