Domoticz authorization error
ressof
- Domoticz version: Latest
I get "Domoticz authorization error" when I try to connect to dashticz. I have dashticz on an alpine machine with nginx and php8.
I have the latest beta version of both domoticz and dashticz.
This is my CONFIG.js file
config['domoticz_ip'] = 'http://192.168.0.10:8080';
config['app_title'] = 'Dashticz V3';
config['user_name'] = 'dashticz';
config['pass_word'] = 'hellohello';
config['enable_websocket'] = 'true';
I get 401 unauthorized in network inspector in chrome and this address http://192.168.0.10:8080/json.htm?usern ... rvariables
When I set trusted networks in domoticz to 192.168.0.* it works but then i dont need to enter credentials for external access.
I have tried with enable basic auth and disabled
- kiddigital
Re: Domoticz authorization error
I assume you are running a recent Beta as many security changes have been done there.
Are you accessing Domoticz through a Proxy? Or has Dashticz direct access?
Username/password as URL parameters is not supported anymore. They need to be sent using a Basic-auth header (‘Authorization: Basic <base64(username:password)>’.
The Basic-Auth API over HTTP setting is to allow this header to be accepted over non-SSL encrypted connections (for example when SSL offloading is done by the Proxy).
ressof
Im running the latest beta of both domoticz and dashticz
Dashticz has direct access to http://192.168.0.10:8080
I have installed dashticz with this command "git clone https://github.com/Dashticz/dashticz --branch beta"
and put CONFIG.js in dashticz/custom/
Is there a setting in dashticz to use Basic-auth?
azonneveld
- Domoticz version: 2024.4
Use base64 to encode your username & password instead of sending it as plain text.
"dashticz:hellohello" ===base64===> "ZGFzaHRpY3o6aGVsbG9oZWxsbw=="
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
ressof
Where in dashticz do I put my base64 converted username and password?
marcoon66
Hi, I have the same problems after updating to the newest build (Version: 2022.2 (build 15050))ressof wrote: Wednesday 25 January 2023 12:35 Where in dashticz do I put my base64 converted username and password?
Where and how (base64) to store username and password in CONFIG.js?
Thanks for your help,
Marco
Lokonli
just use the latest Dashticz beta version, and fill in username and password in CONFIG.js. No need to encode this information.
sailmich
Just updated to new domoticz stable 2023.1 and got also "Domoticz authorization error". Dashticz is already newest beta. I came from 2022.2, domoticz running in docker.
User and password is and was already inside Config.js.
config['user_name'] = 'xxxxxx';
config['pass_word'] = 'xxxxxxx'
I cleared cache I tried chromium still same issue.
Any idea how I can fix that?
- MrMarcie69
- Domoticz version: 2023.1
Same here, just updated and need to login in now. How???sailmich wrote: Tuesday 14 February 2023 20:22 Just updated to new domoticz stable 2023.1 and got also "Domoticz authorization error". Dashticz is already newest beta. I came from 2022.2, domoticz running in docker.
Arguing that you don't care about the right to privacy because you have nothing to hide is no different than saying you don't care about free speech because you have nothing to say. E. Snowden
sailmich
Find a solution! In browser on your Domoticz home page go to Setup > Settings > Security > Trusted Networks. Enter your Network and dashticz can connect
again.
willemd
- Domoticz version: 2024.1
Final resort I update trusted network and replaced last 3 digits with *. Now dashticz has access again.I added username and password to CONFIG.js as explained above (was not there before at all)
I added dashticz as a viewer/user/admin in domoticz (I tried all three).
I cleared the cache (several times)
I updated trusted networks (although was already there before)
I tried 127.0.0.1 in CONFIG.js instead of normal IP
but still I get authorization error when trying to run dashticz against domoticz version 2023.1
mgugu
In one of my deployments, I needed to add ipv6 localhost explicitely, ::1, in the trusted networks. I do not really understand the reason since it was not needed before.
- kiddigital
I thinks it is somewhere in the changelog, but since 2023.1 you have to specify the Trusted network explicitly. Before the IP of the interface was implicitly added to the ‘local network’ (old name).mgugu wrote:In one of my deployments, I needed to add ipv6 localhost explicitely, ::1, in the trusted networks. I do not really understand the reason since it was not needed before.
robgeerts
- Domoticz version: 3.7067
Dashticz is running on: 192.168.1.150:8082
Domoticz is running on: 192.168.1.150:8084
192.168.1.* is in my trusted networks.
I still get an authorization error.
I also tried adding 127.0.0.* etc..
What could be wrong?
Also tried setting user_name and pass_word in config of Dashticz.
No positive result...
EDIT: It works when i set basic auth for API calls in combination with the user_name/pass_word
- Domoticz version: 2025.1
Only set basic auth for HTTP api call should be enough (with trusted networks) . No need for user/password.
What IP do you see in the Domoticz log when dashticz tries to connect?
janportinga
- Domoticz version: 2023-2
Have the same problem
Resolved bij setting domoticz port in https
And set dashticz conf-file also to https
- bayensf
Solved by "Allow Basic-Auth authentication over plain HTTP (API only)" to "On" in Domoticz Security setup in the "Settings" tab.
I got thsi error when I run the latest Domoticz update.
- McMelloW
- Domoticz version: V2024.1
Having the same problem after installing Domoticz 2023.2janportinga wrote: Monday 24 July 2023 15:18 Have the same problem
Where do you set the domoticz port to https?
Greetings McMelloW
janportinga
swilting
- Domoticz version: Last Sta
I also have this error after I updated to the last version of Domoticz,
Is there one simple solution for the issue
*) updated to the Beta version of Dashticz
*) have my IP range in the "trusted network settings" (was already there) (10.0.0.*)
*) try'd the username / password option in the config.js
In my opinion it just shoud work
I can't see any login attempts in the logging of Domoticz, do i have to switch this on somewhere?
