I want to update a humidity device with python
Every sensor of the script is working execpt the Humidity sensor
This is the part of the script
Domoticz.Device(Name="Luchtvochtigheid", Unit=RoomHumidity, Type=81, Subtype=1, Used=1).Create()Code: Select all
def onMessagetoonTSCinfo(self, Connection, Response):
Domoticz.Debug("onMessagetoonTSCinfo called")
if 'humidity' in Response:
humidity=float(Response['humidity'])
strhumidity="%.1f" % humidity
temperature=float(Response['temperature'])
strtemperature="%.1f" % temperature
UpdateDevice(Unit=RoomHumidity, nValue=0, sValue=strtemperature+";"+strhumidity)
2023-01-09 16:39:08.910 Toon: Device: 14 - ID: 637, Name: 'Toon - Luchtvochtigheid', nValue: 0, sValue: '18.8;58.0'
2023-01-09 16:40:08.187 Toon: Update 0:'18.8;58.1' (Toon - Luchtvochtigheid)
2023-01-09 16:47:37.221 Toon: Update 0:'18.7;58.2' (Toon - Luchtvochtigheid)
2023-01-09 16:47:57.224 Toon: Update 0:'18.7;58.3' (Toon - Luchtvochtigheid)
2023-01-09 16:48:17.203 Toon: Update 0:'18.7;58.2' (Toon - Luchtvochtigheid)I've using device type=81, but also device type=82 (temp+hum) is not working
The information is read, but no info in the device
