Neo Coolcam PIR ID=1036
HarryB
Domoticz version: 2022-2
Post by HarryB »
Hi there,
I bought some new Neo Coolcam Pir's, although they look exactly like the model PDZ-02, they have a different hardware.
They are not recognized and give ID=1036, tried to use the nas-pd02z.xml in manufactor_specific.xml but that does not work.
I see that they have motion, lux, temp & humidity now, humidity is a new feature.
BTW this is not the 7z series, got those finally operational.
I hope there is an XML file out there.
Raspberry 4
Aeotec Z-stick ZW-090Z
Domoticz 2022-2
marshall
Re: Neo Coolcam PIR ID=1036
Post by marshall »
I used nas-pd03z.xml and changed the id from 1031 to 1036.
Updating the parameters doesn't work but i edited the file and changed the default values to the values i want.
It sort of works, values differ from my older pirs (lux level much lower) but at least i can use it as a motion sensor.
Neo coolcam answered me this version is updated to zwave 700.
I asked them to send me an up to date xml.
Domoticz version: 2026.3
HarryB
Post by HarryB »
I also asked Coolcam for an updated XML but they told me that they don't have that.
It was also mentioned that this is the Z-Wave 700 chip.
In the mean time I have 3 of them and can't really configure them.
Wish somebody could create a working XML for this device.
There is also a temperature and humidity sensor in this one.
@walterevl I saw that link already, but it is about Open Hab and the XML file is not for Domoticz.
marshall
Post by marshall »
This XML sort of works
nas-pd03z.xml
(7.33 KiB) Downloaded 60 times
HarryB
Post by HarryB »
This XML is not working either, you can't config the parameters.
I hope it will work sooner or later in the new Z-wave zwave2mqtt.
This is a new device with more functionality, I would think it is already used somewhere.
marshall
Post by marshall »
Open the file and edit the value to what you want it to be.
