Hansbit
I've updated the default frontpage.html page
Most important changes:
- The html is cleaned and structured. User settings are now only at end of script.
- All cells are numbered. If cell is not defined in user settings, the cell number appears on screen
- User can now easily set the label of the cell in the user settings (like 'Temperature Livingroom')
- User can now set optional alarm value. Of value of sensor above this value, the text will turn to RED.
- User can easily adjust the color of the text.
- If defined cell is a switch, the cell is clickable to switch that device.
How to install?
- copy attached frontpage.html to the Domoticz ditrectory (domoticz/www)
- Create a roomplan in Domoticz and add devices to that roomplan
- Adjust user settings in frontpage.html: the URL of your domoticz, the number of your roomplan and the devices to display
- If log-in for Domoticz is required, it best to add the IP of the device displaying the frontpage to the settings in Domiticz, so no login is required.
- Open in browser [your Domoticz IP]:8080/frontpage.html
Please send me your comments!
Hans
How to install?
Hans
jannl
- Domoticz version: 2026.1.x
PLaying with this sometime, but only get ?? in a cell if I get any.
Looking at he frontpage.html and the code it seems to be different in page.arry, but not sure
Edit: lamp switching works now, explanantion was not completely clear to me
Edit2: Scenes toegevoegd, maar dit door die hele riedel te kopieren en een extra pagearray aan te maken, kan dit evt. ook slimmer?
And btw, looks great so far
dba59
- Domoticz version: last
hi
i use domoticz on a raspberry and i get this error when i open your html page
inflating: __MACOSX/._frontpage.html
Mac OS X 2u�SMLdSMULATTR����com.apple.TextEncoding�m%com.apple.metadata:kMDItemWhereFromsh?com.apple.quarantineutf-8;134217984bplist00�_>sftp://pi14.hekellaan.nl/home/hans/domoticz/www/frontpage.html Kq/0001;54a14d64;Cyberduck;EEBD982A-D864-4197-8969-2D561087BBAA-
Hansbit
Hello dba59,
I uploaded a new file to the first posting. Please try this one, it is compressed with tar.
Hans
Hans
dba59 wrote:hi
Mac OS X 2
Hansbit
Jan_nl,
What do you mean by page.arry? It should work fine with only one file (frontpage.html).
Please check if you see your devices with http://[YOURIP]:8080/json.htm?type=devices&plan=[ROOMPLANNUMBER] It should output the status from your devices in json format.
Hans
Hans
jan_nl wrote:PLaying with this sometime, but only get ?? in a cell if I get any.
ThinkPad
Awesome, will try this very soon!
Seems like something i can use perfectly for displaying on a cheap 7" Android tablet (Colorfly E708 Q1, €55 from Banggood.com) i bought recently.
Oh, and i think it is advisable to put a reference to Pieter from Bwired in your post
Because it is his code that you are using
pipari
I like the layout very much. But does not seem to get it working.
Edited the User veribles:
example:
$.roomplan=8; // define roomplan in Domoticz and create items below.
$.domoticzurl="http://192.168.1.243:8080";
'59', 'Temp', 'cell3', 'Temp Outside (ºC)', 'color:darkorange', '>25'],
This gives me nothing...
also tried:
$.domoticzurl="domoticz.pipari.nu:8080";
What do I miss?
See attached image
example:
also tried:
What do I miss?
See attached image
- no output at all
- Screen Shot 2014-12-30 at 14.05.16 .png (42.04 KiB) Viewed 112287 times
ThinkPad
I can't open the .tar.gz file. Please post it as a .zip, or upload the content of the HTML file somehwere (http://www.pastebin.com for example).
Edit: managed to get to the source of the HTML file and paste that in a empty 'frontpage.html' file i created. But please upload like .zip or post code somewhere
Some things:
- Celsius symbol not rendering in Chrome (on Windows and Android), use instead
- I had to change 'localhost' to the IP of my Domoticz installation. Probably has something to do with password protection for external users.
I also don't like the font very much, but that is something i can easily change myself
Some things:
°C- I had to change 'localhost' to the IP of my Domoticz installation. Probably has something to do with password protection for external users.
Hansbit
Hi Pipari,
When you enter this URL in a browser, does it give any result?
http://192.168.1.243:8080/json.htm?type=devices&plan=8
Hans
Hans
pipari wrote: $.roomplan=8; // define roomplan in Domoticz and create items below.
Hansbit
Thinkpad,
I've changed the Celsius symbol. Will upload new version in a few days in .zip. The (Google) font can be changed easily. Search for Orbitron in file.
Thanks for comments!
Hans
Hans
ThinkPad wrote: Some things:
- Celsius symbol not rendering in Chrome (on Windows and Android), useinsteadCode: Select all
°C
ThinkPad
I already succeeded
Changed it to some other Google font
Some other points:
- Do you know how to get my today's gas consumption in the page? I have my Domoticz connected to my smart meter (P1).
'CounterToday' is working for electrics, but not for gas (item is not shown then). How do i know what type my device is? Which JSON command can i run to determine?
- And it also seems it can't get the status of a protected switch? I have a switch that controls a GPIO pin. I already have made it unprotected, but still not visible.
- And i have a dimmer, but that one messes up the layout:
(my eettafel (cell 12) is a dimmer)
- And how can i give the words 'on' and 'off' different colors? I would like to have 'On' in green, and 'Off' orange... But can't find how to do it. It looks like the words are directly used from the JSON.
I now have this:
The texts for On and Off do have different colors (blue and green) now, but now i can't click them anymore. I have the feeling i am very close, but can't get it working
Some other points:
(my eettafel (cell 12) is a dimmer)- And how can i give the words 'on' and 'off' different colors? I would like to have 'On' in green, and 'Off' orange... But can't find how to do it. It looks like the words are directly used from the JSON.
I now have this:
if (typeof vdata == 'undefined') {
vdata="??";
} else {
// remove too much text
vdata=new String(vdata).split("Watt",1)[0];
vdata=new String(vdata).split("kWh",1)[0];
if (vdata == 'On') {
vdata='<font color=\'blue\'>On</font>';
if (vdata == 'Off') {
vdata='<font color=\'green\'>Off</font>';
}I am not active on this forum anymore.
ThinkPad
I got it
I modified (or better: left out) parts of the alarmcss, and put in my own code.
Switch is now green when on, and orange when off. The protected/virtual switches are now also suddenly working (something wrong with the original alarmcss code).
Gasmeter was also 'CounterToday'.
Code can be found here:
http://pastebin.com/4gCp13aJ
Things i am still not happy about:
- The dimmer level that is shown huge... For me on/off would be fine, i almost don't change the level, and otherwise would be possible from Domoticz, to keep this interface neat and tidy (no unneccasary dim sliders)
- Protected switches can now be clicked on, and changed from off to on or vice versa > not what you want.... Maybe implement an extra check so a switch cannot be controlled if it is protected? (protected yes/no should already be in JSON data).
Last edited by ThinkPad on Saturday 03 January 2015 15:33, edited 2 times in total.
jannl
@hansbit: pagearray is the array used for the switches etc.
I now see I type some in Dutch
I think this will make me look for a 7" tablet for wall mounting.
First I will have a look at the changes thinkpad made, because I also like that font better.
And see if the scene adaption can be made better compared to just copying all the code.
Heisenberg
Looks nice but is it possible to constantly have the tablet screen on ( in case of build in to cabinet door in the kitchen or wall mount)?
And how to modify it to dark and light interface?
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
ThinkPad
I use this tablet: Banggood.com: Colorfly E708 Q1 Quad Core A31S 7 Inch IPS Android 4.2 Tablet. A while ago it was 55 euros (free shipping). But took a month to arrive
And for dark and light interface, this: https://stackoverflow.com/questions/435 ... javascript could be something nice. Maybe together with pulling sunrise/sunset times from Domoticz.
I am looking for something to automatically turn the screen of the tablet off if a scene in Domoticz is activated (scene 'Sleeping'). Maybe something with 'Tasker' app. But i don't have much time this period to look at it. But just posting my ideas here, for someone else to pick it up maybe
- bbqkees
- Domoticz version: 4.1x
What about wrapping these panels in a slider?
Should not be that much work I think.
With a tablet you could swipe between panels.
You can use something like:
http://liquidslider.com/
jannl
Created something to display/use a link. Not sure if I am goinf to use it, but anyway, below is how I did it.
Add this to the uservariables:
And this after the last } of the if statement that looks like : if ( $.PageArray[ii][0] === item.idx )
['0','Link', 'cell22', '<a href="http://www.nu.nl" target="_blank">NU.nl</a>'],
else if ( $.PageArray[ii][0] === '0' ) { //Special nummer, link in cell (test)
var vlabel= $.PageArray[ii][2]; // cell number from HTML layout
var vdata= $.PageArray[ii][3]; // description (link in this case
var vdesc = '';
$('#'+vlabel).html( '<div>'+vdata+'</div>');
$('#desc_'+vlabel).html(vdesc);
ThinkPad
Good idea!
Also useful for going quickly to Buienradar for example (just before leaving home).
jan_nl, do you have any idea how to implement buttons for a dimmer?
Like the temp control here: http://www.bwired.nl/dash/ipad.asp but then for a dimmer..
jannl
hm, I am going to need them as well in the near future
I see bwired hardcoded almost everything.
With the plus/min and the ChangeStatus function something should be possible I guess. I added a SceneToggle function to the original frontpage.html because the command is different.
I never did much with java(script), so if anyone has more knowledge......please help.
BTW, you ever looked at bwired.nl
pipari
Yes the json request gives me the right result... Maybe I missed something. Will give it a new try tomorrow.
Best Regards
Best Regards
Hansbit wrote:Hi Pipari,
Hans
