Arilux AL-LC0x hardware
mojso
Post by mojso »
where can i find the ip addresses of the devices made through the Arilux AL-LC0x hardware
Domoticz version: 2026.3
Re: Arilux AL-LC0x hardware
The Ip adress can be found in the website of your wifi router. Also an application like Fing.com can help you find all connected devices in your home network.
mojso
Post by mojso »
waltervl wrote: Thursday 15 December 2022 20:03 The Ip adress can be found in the website of your wifi router. Also an application like Fing.com can help you find all connected devices in your home network.
Yes, of course the IP address can be found in my router, but the problem is that it was assigned a static IP address different from the one assigned by the DHCP server, I reset the router and normally I could not remember what the IP address was, so my question was can i find it somewhere in domoticz. specifically in the device that is created by the Arilux hardware plugin
If you have entered an IP address you probably will have done that in the hardware configuration.. menu setup - hardware and select the active Arilux device.
mojso
Post by mojso »
waltervl wrote: Saturday 17 December 2022 0:28 If you have entered an IP address you probably will have done that in the hardware configuration.. menu setup - hardware and select the active Arilux device.
Yes exactly. But if you don't know the correct IP address of the device which is made through Arilux hardware device, the device cannot be used through domotics until you find the correct IP address or if you create a new device. I also searched in the database (domoticz.db) but could not find it.
