Dial with battery level
michelscholte
Post by michelscholte »
I've got several dials for every temp sensor. Is it possible to add the battery level to a dial block?
For example:
Lokonli
Re: Dial with battery level
Post by Lokonli »
I can add that in a next release.
I could add the battery level indicator within the dial just below the date. Would that be OK? Or do you prefer outside the dial as in your picture?
Verstuurd vanaf mijn SM-A526B met Tapatalk
michelscholte
Hi Lokonli,
I prefer it outside the dial, otherwise the data in the dial wil be less orderly on my 7" tablet. :-) If it is possible of course.
Thank you in advance.
Renber
Post by Renber »
I am also interested. But I would prefer in the (cleaner) dial. Below the name, there is a little space, right?
Otherwise do both ;-)
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
Krenstik
Post by Krenstik »
if anyone is interested:
Renber
Post by Renber »
I am, but how do you do it?
Krenstik
Post by Krenstik »
blocks['pco'] = { idx: 43, decimals: 0 , type: 'dial', width: 2, title: 'Pracovna', showunit: true,
shownumbers: true, showring: true, last_update: true, setpoint: 1400, min: 400, max: 2700, color: '#26e500',
values : [
{ value: 'Quality',label:'status', type: 'text', idx: 43 ,addClass: 'w100' },
{ value: 'BatteryLevel', idx: 43 , unit:' %', icon: 'fas fa-battery-full', }, ]} //
michelscholte
Krenstik,
Thanks a lot for this suggestion. Unfortunately wil this not change the icon when the battery level is changed. But it is a nice workaround for the moment. Hopefully Lokonli will make the possibility for us with a simple option within the config.js file.
But still thanks for your response.
