Hi. I'm sorry, my english is poor..
I did install for Openmediavault - Portainer docker container. (latest) Omv is 6.11. Starting fine, after cca 1 minute this error (log file):
Img is attachment...
Not started...
For OMV install, "Error opening SQLite3 database"
- Képernyőkép_2022-12-15_11-56-02.png (102.89 KiB) Viewed 978 times
willemd
- Domoticz version: 2026.3
Re: For OMV install, "Error opening SQLite3 database"
Did you check manually whether the domoticz database exists in the folder /usr/share/domoticz/ ?
Find / -name "domoticz.db" - not found...
In /usr/share directory no "domoticz" dir...
Did you have a mounted folder? See docker instruction https://hub.docker.com/r/domoticz/domoticz
Hi.
I see the link, but I not found "mount" folder (only timezone)..
I have 7 another program in Docker: Plex, MStream (use DB), Homeassistant, torrent, ect.. All perfect.
In OMV6 install full new, no need manually mkdir, create yml file, ect..:
- Képernyőkép_2022-12-16_08-25-15.png (135.67 KiB) Viewed 937 times
Sorry I meant volumes:
volumes:
- ./config:/opt/domoticz/userdata
The database will be created in userdata.
Please also check the synology docker instructions for some reference (ignore the USB driver part)
https://www.domoticz.com/wiki/Synology
volumes:
