Problem with sound
Renber
Problem with sound
Post by Renber »
I have a strange behavior with sounds.
Considering the dashticz page was just refreshed and the block is using "playsound"
The state of a swtich is changed by dashticz -> The sound works and it will work even if the state is then changed by domoticz
But if the state of a switch is changed by domoticz first -> No sound (even if the state is changed after with dashticz)
I hope I'm clear enough because it's translation.
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
Lokonli
Re: Problem with sound
Post by Lokonli »
Most browsers now only will play sound after user interaction like clicking a button.
You can try to save Dashticz on your home screen and start it from there.
Verstuurd vanaf mijn SM-A526B met Tapatalk
Renber
Post by Renber »
OK, I understand better. Your solution didn't work. I imagine there is no workaround possible.
thank you for your reply
Renber
Post by Renber »
I found the solution which I put here for Chrome.
You must add the address of your dashticz server in: chrome://settings/content/sound
Works perfectly !
Lokonli
Post by Lokonli »
Thanks! I'll include that in the documentation.
