Change Hardware .cpp file
JeroNeo
Domoticz version: 4.10532
Post by JeroNeo »
I am trying to add changes to a .cpp file in the hardware dir
but i cannot get this to work.
I have Debian 11 and compiled Domoticz (V2022.2 (build 14784)) according to this guide: https://www.domoticz.com/wiki/Build_Dom ... rom_source
I open up lets say /dev-domoticz/hardware/SatelIntegra.cpp and change some log lines and saved them. then preform:
$ sudo make
i see that the file i have edited is changed and being added
after that i preform:
$ ./domoticz
but do not see my changes i have added at the log line.
I think i am missing a step.
Best regards,
Jero
OrangePi Plus 2e with Armbian Buster.
1x Evohome setup (6x radiators), 1x Tuya floorheater bathroom,
1x RGBW led strip, Satel INTEGRA 256+
IKEA-Trädfri Gateway with 48 controlable lights COAP-Client,
SolarEdge inverter, homebrew P1 meter.
Domoticz version: 2026.3
Re: Change Hardware .cpp file
First, I never build domoticz myself so perhaps I am saying something stupid....
Do you start ./domoticz in the /dev-domoticz (build)folder or in the /domoticz (installed) folder? It should be in de dev-domoticz folder i suppose.
Is the domoticz executable modified in the folder you have manualy started domoticz?
JeroNeo
Post by JeroNeo »
started it from dev-domoticz and also i need to start it manually
ferrosk
Domoticz version: 2026.2
Post by ferrosk »
JeroNeo wrote: Friday 02 December 2022 9:03 after that i preform:
$ ./domoticz
It should work like that. When you start re-built domoticz, in startup logs, do you see "-modified" flag added in "Build Hash:" message? It indicates that you really started domoticz built from modified source files, in example:
2022-12-02 17:03:06.906 Status: Domoticz V2022.2 (build 14789) (c)2012-2022 GizMoCuz
2022-12-02 17:03:06.906 Status: Build Hash: e51770e85-modified, Date: 2022-12-02 09:15:37
Domoticz 2026.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
JeroNeo
Post by JeroNeo »
ferrosk wrote: Friday 02 December 2022 17:24
$ ./domoticz
there is the issue, i am getting:
2022-12-05 08:15:56.161 Status: Domoticz V2022.2 (build 14784) (c)2012-2022 GizMoCuz
2022-12-05 08:15:56.161 Status: Build Hash: e04d1d3e2, Date: 2022-11-29 07:53:03
2022-12-05 08:15:56.161 Status: Startup Path: /home/domoticz/dev-domoticz/
Without -modified. i have restarted the server and did the steps again it does not change to modified.
gizmocuz
Post by gizmocuz »
I don't think you need to issue any 'sudo' command when building
Please note that the executable could be build inside the 'bin' folder
JeroNeo
Post by JeroNeo »
gizmocuz wrote: Monday 05 December 2022 8:52 I don't think you need to issue any 'sudo' command when building
Thank you for pointing out the "bin" folder.
this does the trick.
i can now see and test my changes. and they are working.
