Sonoff Zigbee 3.0 USB dongel Plus -E, ZigBeeforDomoticZ plugin compatibility issues
Knight
Domoticz version: 2024.7
Post by Knight »
Hi, I have compatibility issues with my Sonoff Zigbee 3.0 USB Dongle Plus E.
When I flash it to a router, I cannot include it in my network as the ZigBeeforDomoticZ plugin sees it as Unknown. Is there any way to add it to the database?
Sonoff Zigbee 3.0 USB Dongle Plus E works as an Cordinator but Firmware is unknown.
https://sonoff.tech/wp-content/uploads/ ... shing-.pdf
'PairingInProgress': True, 'ConsistencyCheck': 'Bad Pairing'}
2022-11-27 23:24:40.959 Error: Zigbee: Not Loading e701 as Status: UNKNOW
2022-11-27 23:30:55.072 Error: Zigbee: [6] NEW OBJECT: 88cf Not able to get all needed attributes on time
2022-11-27 23:30:55.072 Error: Zigbee: processNotinDB - not able to find response from 88cf stop process at 0043
2022-11-27 23:30:55.084 Error: Zigbee: processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '01', 'Ep': {'01': {'0000': {'0004': 'SONOFF', '0005': 'DONGLE-E_R'}}, '02': {'0000': {'0004': 'SONOFF', '0005': 'DONGLE-E_R'}}, 'f2': {}}, 'Heartbeat': '1', 'RIA': '6', 'LQI': 94, 'Battery': {}, 'Model': 'DONGLE-E_R', 'ForceAckCommands': [], 'MacCapa': '8e', 'IEEE': '84b4dbfffefcf692', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'FFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'Router', 'Manufacturer': '', 'Manufacturer Name': 'SONOFF', 'NbEp': '3', 'PowerSource': 'Main', 'ReadAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 1669588225, 'iSQN': {'0004': '00', '0005': '00'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}}, '02': {'0000': {'TimeStamp': 1669588225, 'iSQN': {'0004': '01', '0005': '01'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}}, 'f2': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1669588225.7053828, 'Time': '2022-11-27 23:30:25', 'MsgType': '8100', 'LastSeen': 1669588225}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'ZDPSQN': '01', 'Epv2': {'01': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, '02': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, 'f2': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'ZCLSQN': '01', 'PairingInProgress': True, 'ZCL-IN-SQN': {'0000': '01'}, 'RollingLQI': [94, 94], 'ConsistencyCheck': 'Bad Pairing'}
2022-11-27 23:36:50.818 Error: Zigbee: Not Loading 88cf as Status: UNKNOW
pipiche
Re: Sonoff Zigbee 3.0 USB dongel Plus -E, ZigBeeforDomoticZ plugin compatibility issues
Post by pipiche »
If you flash it with a router firmware, from the log we can know that the router has joined the network.
I'll see what I can do and will come back to you
pipiche
Post by pipiche »
If you can switch to the dev branch, assuming that you are at least on 6.3.00x
git pull
git checkout dev
git pull
restart the plugin, and redo the pairing, no widget will be created into Domotciz, but you should get the device in plugin with a status notDB (which stand not in Domoticz)
Knight
Post by Knight »
Hello, here it the complete log
Lof from Domoticz
2022-11-29 18:26:58.447 Status: Zigbee: Request Accepting new Hardware for 240 seconds
2022-11-29 18:26:58.543 Status: Zigbee: Accepting new Hardware: Enable (On)
2022-11-29 18:27:17.688 Status: Zigbee: [None] NEW OBJECT: 029e None
2022-11-29 18:27:17.897 Status: Zigbee: [-] NEW OBJECT: 029e Active Endpoint Response Ep: 01 LQI: 0
2022-11-29 18:27:17.897 Status: Zigbee: [-] NEW OBJECT: 029e Active Endpoint Response Ep: 02 LQI: 0
2022-11-29 18:27:17.898 Status: Zigbee: [-] NEW OBJECT: 029e Active Endpoint Response Ep: f2 LQI: 0
2022-11-29 18:27:17.905 Status: Zigbee: [-] NEW OBJECT: 029e Request Simple Descriptor for Ep: 01
2022-11-29 18:27:22.106 Status: Zigbee: [0] NEW OBJECT: 029e Model Name: DONGLE-E_R
2022-11-29 18:27:22.107 Status: Zigbee: [0] NEW OBJECT: 029e Manufacturer Name: SONOFF
2022-11-29 18:27:27.111 Status: Zigbee: [1] NEW OBJECT: 029e Model Name: DONGLE-E_R
2022-11-29 18:27:27.112 Status: Zigbee: [1] NEW OBJECT: 029e Manufacturer Name: SONOFF
2022-11-29 18:27:32.089 Status: Zigbee: [2] NEW OBJECT: 029e Model Name: DONGLE-E_R
2022-11-29 18:27:32.090 Status: Zigbee: [2] NEW OBJECT: 029e Manufacturer Name: SONOFF
2022-11-29 18:27:37.071 Status: Zigbee: [3] NEW OBJECT: 029e Model Name: DONGLE-E_R
2022-11-29 18:27:37.072 Status: Zigbee: [3] NEW OBJECT: 029e Manufacturer Name: SONOFF
2022-11-29 18:27:39.958 Zigbee: UpdateDevice - (Zigbee Garage Nere inkl baro) 0:15.7;48.6;1;1033.6;1
2022-11-29 18:27:40.015 Zigbee: UpdateDevice - (Zigbee Garage Nere) 0:15.7;48.6;1
2022-11-29 18:27:40.030 Zigbee: UpdateDevice - (Zigbee Garage Nere, Temp) 15.7:15.7
2022-11-29 18:27:40.039 Zigbee: UpdateDevice - (Zigbee Garage Nere inkl baro) 0:15.7;48.4;1;1033.6;1
2022-11-29 18:27:40.046 Zigbee: UpdateDevice - (Zigbee Garage Nere) 0:15.7;48.4;1
2022-11-29 18:27:40.085 Zigbee: UpdateDevice - (Zigbee Garage Nere inkl baro) 0:15.7;48.4;1;1033.7;1
2022-11-29 18:27:40.121 Zigbee: UpdateDevice - (Zigbee Garage Nere, Baro) 0:1033.7;1
2022-11-29 18:27:42.107 Status: Zigbee: [4] NEW OBJECT: 029e Model Name: DONGLE-E_R
2022-11-29 18:27:42.110 Status: Zigbee: [4] NEW OBJECT: 029e Manufacturer Name: SONOFF
2022-11-29 18:27:47.094 Status: Zigbee: [5] NEW OBJECT: 029e Model Name: DONGLE-E_R
2022-11-29 18:27:47.097 Status: Zigbee: [5] NEW OBJECT: 029e Manufacturer Name: SONOFF
2022-11-29 18:27:52.066 Status: Zigbee: [6] NEW OBJECT: 029e Model Name: DONGLE-E_R
2022-11-29 18:27:52.072 Status: Zigbee: [6] NEW OBJECT: 029e Manufacturer Name: SONOFF
2022-11-29 18:27:52.060 Error: Zigbee: [6] NEW OBJECT: 029e Not able to get all needed attributes on time
2022-11-29 18:27:52.060 Error: Zigbee: processNotinDB - not able to find response from 029e stop process at 0043
2022-11-29 18:27:52.060 Error: Zigbee: processNotinDB - Collected Infos are : {'Version': '3', 'ZDeviceName': '', 'Status': 'UNKNOW', 'SQN': '01', 'Ep': {'01': {'0000': {'0004': 'SONOFF', '0005': 'DONGLE-E_R'}}, '02': {'0000': {'0004': 'SONOFF', '0005': 'DONGLE-E_R'}}, 'f2': {}}, 'Heartbeat': '1', 'RIA': '6', 'LQI': 76, 'Battery': {}, 'Model': 'DONGLE-E_R', 'ForceAckCommands': [], 'MacCapa': '8e', 'IEEE': '84b4dbfffefcf692', 'Type': {}, 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'FFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'Router', 'Manufacturer': '', 'Manufacturer Name': 'SONOFF', 'NbEp': '3', 'PowerSource': 'Main', 'ReadAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 1669742838, 'iSQN': {'0004': '00', '0005': '00'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}}, '02': {'0000': {'TimeStamp': 1669742838, 'iSQN': {'0004': '01', '0005': '01'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}}, 'f2': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1669742840.2033675, 'Time': '2022-11-29 18:27:20', 'MsgType': '8011', 'LastSeen': 1669742840}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'ZDPSQN': '01', 'Epv2': {'01': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, '02': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, 'f2': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'ZCLSQN': '01', 'ZCL-IN-SQN': {'0000': '01'}, 'RollingLQI': [72, 76], 'WriteAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}, '02': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'PairingInProgress': True, 'ConsistencyCheck': 'Bad Pairing'}
Here is the log from Sonoff Zigbee 3.0 USB dongel Plus -E
> appNwkJoinOrRejoinWhenPowerOn [328]:
start nwk join EVENT,sta = 0x00
NWK Steering scan complete. Beacons heard: 1
NWK Steering State: Scan Primary Channels and use Install Code
Error: install code setup failed. Is an install code flashed onto the device?
Error: NWK Steering could not setup security: 0xB7
Examining beacon on channel 15 with panId 0x72BD
NWK Steering joining 0x72BD on channel 15
EMBER_NETWORK_UP 0x029E
NWK Steering stack status 0x90
NWK Steering network joined.
>>>> Joined chan = 15, PanId = 0x72BD, nwkAddr = 0x029E, txPower = 20
RX: ZDO, command 0x0013, status: 0x00
Device Announce: 0x029E
T00000000:RX len 7, ep 01, clus 0x0000 (Basic) FC 10 seq 00 cmd 00 payload[04 00 05 00 ]
> appNwkJoinOrRejoinWhenPowerOn [291]:
NWK attempt join EVENT, nwk_state = 0x02, appDevHadAttemptNwkJoinTimes = 7
> appNwkJoinOrRejoinWhenPowerOn [360]:
NWK join EVENT:EMBER_JOINED_NETWORK, app_dev_had_attempt_nwk_join_times = 8
T00000000:RX len 7, ep 02, clus 0x0000 (Basic) FC 10 seq 01 cmd 00 payload[04 00 05 00 ]
T00000000:RX len 5, ep 01, clus 0x0000 (Basic) FC 10 seq 00 cmd 0B payload[01 00 ]
T00000000:RX len 5, ep 02, clus 0x0000 (Basic) FC 10 seq 01 cmd 0B payload[01 00 ]
Update TC Link Key: Starting update trust center link key process: 0x00
RX: ZDO, command 0x8002, status: 0x00
RX: Node Desc Resp, Matches: 0x0000
Update TC Link Key: New key established: 0x03
Partner: 49 26 B7 26 00 4B 12 00
NWK Steering: Trust center link key update status: 0x03
Update TC Link Key: New key established: 0x65
NWK Steering: Trust center link key update status: 0x65
EMBER_NETWORK_OPENED: 180 sec
pJoin for 180 sec: 0x00
NWK Steering: Broadcasting permit join: 0x00
NWK Steering Stop. Cleaning up.
Join network complete: 0x00
pipiche
Post by pipiche »
which version of the plugin did you use ?
Knight
Post by Knight »
ZigBeeforDomoticZ plugin Admin Interface Version 6.3.006
I notice that Plus-E use EFR32MG21 Chip. Maybe its only supported in the beta?
https://sonoff.tech/product/gateway-amd ... le-plus-e/
Knight
Post by Knight »
pipiche wrote: Monday 28 November 2022 22:10 If you can switch to the dev branch, assuming that you are at least on 6.3.00x
git pull
git checkout dev
git pull
I got an error when i write git pull.
pi@raspberrypi:~ $ git pull
fatal: inte ett git-arkiv (eller någon av föräldrakatalogerna): .git
Do you want me to upgrade to the beta ?
I got this error when i restart the plugin and the Router fall out
0: Object {"Time":"29/11/2022 19:50:34","Module":"Database","nwkid":"None","PluginHealth":"Startup","message":"Not Loading 029e as Status: UNKNOW","PermitToJoin":{"Duration":0,"Starttime":1669747859},"Thread":"MainThread"}
LastLog: 0
StartTime: "29/11/2022 19:50:33"
FirmwareVersion: "0219"
FirmwareMajorVersion: "22"
PluginVersion: Array[1] ["stable6-6.3.006"]
LastLog: 2
pipiche
Post by pipiche »
I don't understand what the error message is. But it could be that you need to be root to run the git command in that case
sudo git pull
sudo git checkout dev
sudo git pull
Knight
Post by Knight »
Update --------ZigBeeforDomoticZ plugin Admin Interface
Version 6.4.040--------
Did I move to a beta now?
God news! after upgrade to 6.4.040 and some restarts the repeater connect to the network! and it seems to work now :shock: :) :) . I have not tried my old domoticz, this is a new one with fresh iso.
I Use one Sonoff Zigbee 3.0 USB dongel Plus -E as cordinator and one Sonoff Zigbee 3.0 USB dongel Plus -E as repeater
i@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo git checkout dev
Grenen dev ställdes in att spåra fjärrgrenen "dev" från "origin".
Växlade till en ny gren "dev"
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo git pull
tips: Det avråds från att göra "pull" utan att ange hur avvikande grenar
tips: ska förlikas. Du kan ta bort det här meddelandet genom att köra ett av
tips: följande kommandon innan du gör "pull" nästa gång:
tips:
tips:   git config pull.rebase false  # sammanslagning (förvald strategi)
tips:   git config pull.rebase true   # ombasering
tips:   git config pull.ff only       # endast snabbspolning
tips:
tips: Du kan ersätta "git config" med "git config --global" för att välja en
tips: förvald inställning för alla arkiv. Du kan också ange --rebase, --no-rebas                                    e
tips: eller --ff-only på kommandoraden för att överstyra det konfigurerade
tips: förvalet vid körning.
Hämtar undermodulen external/bellows
Hämtar undermodulen external/zigpy
Hämtar undermodulen external/zigpy-deconz
Hämtar undermodulen external/zigpy-zigate
Hämtar undermodulen external/zigpy-znp
Redan à jour.
Domoticz Log
2022-12-07 07:01:41.960 Zigbee: Worker thread started.
2022-12-07 07:01:41.506 Status: Zigbee: Statistics on message
2022-12-07 07:01:41.506 Status: Zigbee: PDM load(s) : 0
2022-12-07 07:01:41.506 Status: Zigbee: ZiGate reacting time
2022-12-07 07:01:41.507 Status: Zigbee: Max : 0 sec
2022-12-07 07:01:41.507 Status: Zigbee: Average : 0 sec
2022-12-07 07:01:41.507 Status: Zigbee: ZiGate processing time on Rx
2022-12-07 07:01:41.507 Status: Zigbee: Sent:
2022-12-07 07:01:41.507 Status: Zigbee: TX commands : 2
2022-12-07 07:01:41.507 Status: Zigbee: Max Load (Queue) : 1
2022-12-07 07:01:41.507 Status: Zigbee: Max aPDU (Queue) : 0
2022-12-07 07:01:41.507 Status: Zigbee: Max nPDU (Queue) : 0
2022-12-07 07:01:41.507 Status: Zigbee: TX failed : 0 (0.0%)
2022-12-07 07:01:41.507 Status: Zigbee: TX timeout : 0 (0.0%)
2022-12-07 07:01:41.507 Status: Zigbee: TX data timeout : 0 (0.0%)
2022-12-07 07:01:41.507 Status: Zigbee: TX reTransmit : 0 (0.0%)
2022-12-07 07:01:41.508 Status: Zigbee: TX APS Failure : 0 (0.0%)
2022-12-07 07:01:41.508 Status: Zigbee: TX APS Ack : 1 (50.0%)
2022-12-07 07:01:41.508 Status: Zigbee: TX APS Nck : 0 (0.0%)
2022-12-07 07:01:41.508 Status: Zigbee: Received:
2022-12-07 07:01:41.508 Status: Zigbee: RX frame : 15
2022-12-07 07:01:41.508 Status: Zigbee: RX crc errors : 0 (0.0%)
2022-12-07 07:01:41.508 Status: Zigbee: RX lentgh errors : 0 (0.0%)
2022-12-07 07:01:41.508 Status: Zigbee: RX clusters : 0
2022-12-07 07:01:41.508 Status: Zigbee: RX clusters KO : 0
2022-12-07 07:01:41.508 Status: Zigbee: Operating time : 6 Hours 33 Mins 34 Secs
2022-12-07 07:01:41.943 Status: Zigbee: Exiting work loop.
2022-12-07 07:01:41.960 Status: Zigbee: Stopping threads.
2022-12-07 07:01:41.960 Status: Zigbee: Stopped.
2022-12-07 07:01:41.960 Status: Zigbee: Entering work loop.
2022-12-07 07:01:41.960 Status: Zigbee: Started.
2022-12-07 07:01:41.960 Status: Incoming connection from: 192.168.137.84
2022-12-07 07:01:44.091 Zigbee: Zigbee for Domoticz plugin started!
2022-12-07 07:01:44.173 Internal Sensors: General/Percentage (Memory Usage)
2022-12-07 07:01:44.181 Internal Sensors: General/Custom Sensor (Process Usage)
2022-12-07 07:01:44.088 Status: Zigbee: Initialized version 6.3, author 'pipiche38'
2022-12-07 07:01:44.092 Status: Zigbee: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-12-07 07:01:45.330 Zigbee: load PluginConf
2022-12-07 07:01:45.331 Zigbee: Loading PluginConf - into Domoticz sqlite Db
2022-12-07 07:01:45.332 Zigbee: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json timestamp is 1670361884.0547605
2022-12-07 07:01:45.332 Zigbee: Dz PluginConf is older than Json Dz: 0 Json: 1670361884.0547605
2022-12-07 07:01:45.334 Zigbee: Installing plugin custom page /home/pi/domoticz/www/templates/Zigbee.html
2022-12-07 07:01:45.335 Zigbee: Starting LoggingManagement thread
2022-12-07 07:01:45.338 Zigbee: start_logging_thread
2022-12-07 07:01:45.339 Zigbee: logging_thread - listening
2022-12-07 07:01:45.176 Status: Zigbee: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-12-07 07:01:45.333 Status: Zigbee: PluginAnalytics set to 1
2022-12-07 07:01:45.333 Status: Zigbee: channel set to 15
2022-12-07 07:01:45.334 Status: Zigbee: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json
2022-12-07 07:01:45.334 Status: Zigbee: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-12-07 07:01:45.334 Status: Zigbee: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-12-07 07:01:45.334 Status: Zigbee: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-12-07 07:01:45.334 Status: Zigbee: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-12-07 07:01:45.334 Status: Zigbee: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-12-07 07:01:45.334 Status: Zigbee: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-12-07 07:01:45.334 Status: Zigbee: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-12-07 07:01:45.334 Status: Zigbee: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-12-07 07:01:45.334 Status: Zigbee: ControllerInRawMode set to True
2022-12-07 07:01:45.339 Status: Zigbee: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_03.log
2022-12-07 07:01:45.355 Status: Zigbee: Zigbee for Domoticz (z4d) plugin beta6-6.4.040 started
2022-12-07 07:01:45.392 Status: Zigbee: DeviceConf loaded - 21 confs loaded
2022-12-07 07:01:45.686 Status: Zigbee: DeviceConf loaded - 386 confs loaded
2022-12-07 07:01:45.687 Status: Zigbee: load ListOfDevice
2022-12-07 07:01:45.701 Status: Zigbee: 2 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-3.txt
2022-12-07 07:01:45.710 Status: Zigbee: Transport mode: ZigpyEZSP
2022-12-07 07:01:47.600 Status: Zigbee: Start Zigpy Transport on EZSP
2022-12-07 07:01:47.606 Status: Zigbee: ZigpyTransport: thread_processing_and_sending Thread start.
2022-12-07 07:01:47.616 Status: Zigbee: Start Web Server connection
2022-12-07 07:01:47.657 Status: Zigbee: Web backend for Web User Interface started on port: 9440
2022-12-07 07:01:47.658 Status: Zigbee: Domoticz Widgets usage is at 1.2 % (252 units free)
2022-12-07 07:01:48.223 Status: Zigbee: Started radio ezsp port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220713100541-if00
2022-12-07 07:01:50.405 Status: Zigbee: Number of devices recently active in Zigate = 0
2022-12-07 07:01:50.435 Status: Zigbee: EZSP Radio manufacturer:
2022-12-07 07:01:50.443 Status: Zigbee: EZSP Radio board name:
2022-12-07 07:01:50.445 Status: Zigbee: EmberZNet version: 6.10.3.0 build 297
2022-12-07 07:01:50.458 Status: Zigbee: Network settings
2022-12-07 07:01:50.461 Status: Zigbee: Channel: 15
2022-12-07 07:01:50.463 Status: Zigbee: PAN ID: 0x20CE
2022-12-07 07:01:50.464 Status: Zigbee: Extended PAN ID: 27:c8:c9:8f:06:91:d3:64
2022-12-07 07:01:50.469 Status: Zigbee: Device IEEE: 84:b4:db:ff:fe:f8:2e:11
2022-12-07 07:01:50.470 Status: Zigbee: Device NWK: 0x0000
2022-12-07 07:01:50.493 Status: Zigbee: Installer Version Number: 6.10.3.0 build 297
2022-12-07 07:01:50.494 Status: Zigbee: Branch Version: ==> Unknown Silicon Labs <==
2022-12-07 07:01:50.497 Status: Zigbee: Zigbee Coordinator ieee: 84b4dbfffef82e11 , short addr: 0000
2022-12-07 07:01:50.499 Status: Zigbee: Network state UP, PANID: 20ce extPANID: 0x27c8c98f0691d364 Channel: 15
2022-12-07 07:01:50.489 Error: Zigbee: Untested Zigbee adapater model, please report to the Zigbee for Domoticz team
2022-12-07 07:01:56.090 Status: Zigbee: Request Disabling Accepting new Hardware
2022-12-07 07:02:01.108 Status: Zigbee: coordinator set to Certification : 1/CE -> CE
2022-12-07 07:02:02.184 Status: Zigbee: ota_scan_folder Following Firmware have been loaded
2022-12-07 07:02:02.185 Status: Zigbee: Plugin with Zigpy, Coordinator Unknown Silicon Labs firmware UNK - 6.10.3.0 build 297 correctly initialize
Sonoff Zigbee 3.0 USB dongel Plus -E, PUTTY COM4 Baound 115200
Partner: 11 2E F8 FE FF DB B4 84
ERROR from ZigBeeforDomoticZ plugin Admin Interface
Version 6.4.040
0: Object {"0":{"Time":"06/12/2022 23:18:00","Module":"Input","nwkid":"None","PluginHealth":"Startup","message":"Untested Zigbee adapater model, please report to the Zigbee for Domoticz team","PermitToJoin":{"Duration":0,"Starttime":1670365351},"Thread":"ZigpyForwarder_3"},"LastLog":0,"StartTime":"06/12/2022 23:17:55","FirmwareVersion":"6.10.3.0 build 297","FirmwareMajorVersion":"98","PluginVersion":"beta6-6.4.040"}
1: Object {"0":{"Time":"07/12/2022 00:28:12","Module":"Input","nwkid":"None","PluginHealth":"Startup","message":"Untested Zigbee adapater model, please report to the Zigbee for Domoticz team","PermitToJoin":{"Duration":0,"Starttime":1670392608},"Thread":"ZigpyForwarder_3"},"LastLog":0,"StartTime":"07/12/2022 00:28:07","FirmwareVersion":"6.10.3.0 build 297","FirmwareMajorVersion":"98","PluginVersion":["beta6-6.4.040"]}
2: Object {"0":{"Time":"07/12/2022 07:01:50","Module":"Input","nwkid":"None","PluginHealth":"Startup","message":"Untested Zigbee adapater model, please report to the Zigbee for Domoticz team","PermitToJoin":{"Duration":0,"Starttime":1670392916},"Thread":"ZigpyForwarder_3"},"LastLog":0,"StartTime":"07/12/2022 07:01:45","FirmwareVersion":"6.10.3.0 build 297","FirmwareMajorVersion":"98","PluginVersion":["beta6-6.4.040"]}
LastLog: 2
Last edited by Knight on Wednesday 07 December 2022 8:35, edited 2 times in total.
pipiche
Post by pipiche »
Yes that is a known issue and it is not an issue.
Sonoff E is using a firmware which has not all needed information defined.
We are probably going to remote this error message
Knight
Post by Knight »
It seems to work now, Can you explain what this command does?
sudo git pull
sudo git pull
Thorgal789
Post by Thorgal789 »
Those command are to switch on the "dev" branch.
Knight
Post by Knight »
Im not sure if the repeater works 100%. the repeater is notDB and health is N/A but i dont know what that means.
Log from COM4, Putty 115200
Device Announce: 0xB268
EMBER_NETWORK_OPENED: 240 sec
EMBER_NETWORK_CLOSED
Device Announce: 0x07E2
Device Announce: 0x13BE
pipiche
Post by pipiche »
The repeater is notDb because there is no widget in DomoticZ for it. Which make sense.
wm62
Domoticz version: 4.97
Post by wm62 »
Any chance for a link on how to install a dongle-e? I've ordered the normal version but they end me the 'e' version
pipiche
Post by pipiche »
wm62 wrote: Thursday 22 December 2022 7:27 Any chance for a link on how to install a dongle-e? I've ordered the normal version but they end me the 'e' version
If you want to install a SonOff USB Dongle-E as a coordinator, it is the same way as all others but you need to select Silcon Labs instead of Texas in Domoticz Hardware Menu
Screenshot 2022-12-22 at 08.24.00.png (251.42 KiB) Viewed 2785 times
wm62
Post by wm62 »
thanx! will try immediatly!
Happy Holidays!
