I know this has already been discussed earlier and solutions are already found, but still.
I have hourly electricity prices. I already have scripts to fetch current price from Nordpool and price is showed in Domoticz and a cronjob sets some timers to launch at cheapest hours.
Also I have a 20kWh battery which I charge at cheap hours (or from my solar plant) and then discharge during expensive hours.
All this makes me want to see exact daily/monthly/yearly costs and savings from the battery, but it's not really something Domoticz is able to do.
All electricity meters have the "cost" view in "report" page, there you can see yearly/monthly/daily quite easily and that would be quite enough for me. I figured that i could just modify the "T1 price" in settings page each hour. But it doesn't work like that! If I change the price, it will affect the Report page even in the past!
This seems really silly. Surely energy companies sometimes change their pricing even on fixed plans? Or you might change providers and get different price. If you update the price in Domoticz, it ruins all your price data from past years. Domoticz apparently is only really logging kwh and then uses price*kwh to show the cost.
Energy prices are not really logged
willemd
- Domoticz version: 2026.3
Re: Energy prices are not really logged
I am storing the costs components of my contract in user variables and then use a dzvent script to calculate the actual costs. The results are stored in some custom devices. Could that work for you?
Note it does not take into account the daily low and high rate periods. Only uses high rate in the calculation.
devices = {
-- idx of the Electricity P1 meter
1
logging = {
level = domoticz.LOG_ERROR,
marker = 'costcalc',
execute = function(domoticz)
-- idx numbers need to be adjusted for new installation
-- idx of devices
local idxElectricityP1=1
local idxGasP1=2
local idxElectricityCosts=18
local idxGasCosts=19
local idxTaxCosts=20
local idxTotalCosts=21
-- idx of user variables
local idxElDalTarief=1
local idxElNormaalTarief=2
local idxElTransportRatePerDay=3
local idxElTaxkWh=4
local idxGasTarief=5
local idxGasTransportRatePerDay=6
local idxGasTaxM3=7
local idxDeliveryFixedPerMonth=8
local idxTaxReductionPerDay=9
-- Input Devices --
local todayEl = domoticz.devices(idxElectricityP1).counterToday
local todayElreturn = domoticz.devices(idxElectricityP1).counterDeliveredToday
local todayGas = domoticz.devices(idxGasP1).counterToday
-- Output Devices --
local El_costs = domoticz.devices(idxElectricityCosts)
local Gas_costs = domoticz.devices(idxGasCosts)
local Tax_costs = domoticz.devices(idxTaxCosts)
local Total_costs = domoticz.devices(idxTotalCosts)
-- Variables --
local El_rate_dal = domoticz.variables(idxElDalTarief).value
local El_rate_normal = domoticz.variables(idxElNormaalTarief).value
local El_transport = domoticz.variables(idxElTransportRatePerDay).value
local El_tax = domoticz.variables(idxElTaxkWh).value
local Gas_rate = domoticz.variables(idxGasTarief).value
local Gas_transport = domoticz.variables(idxGasTransportRatePerDay).value
local Gas_tax = domoticz.variables(idxGasTaxM3).value
local Delivery_fixed = domoticz.variables(idxDeliveryFixedPerMonth).value
local Taxreduction = domoticz.variables(idxTaxReductionPerDay).value
local EURO_El = tonumber(domoticz.utils.round((El_rate_normal * (todayEl-todayElreturn) + Delivery_fixed/31 + El_transport),2))
local EURO_Gas = tonumber(domoticz.utils.round(((Gas_rate * todayGas) + Delivery_fixed/31 + Gas_transport),2))
local EURO_Tax = tonumber(domoticz.utils.round((El_tax * (todayEl-todayElreturn)) + (Gas_tax * todayGas),2)) + Taxreduction
local EURO_Total = EURO_El + EURO_Gas + EURO_Tax
El_costs.updateCustomSensor(domoticz.utils.round(EURO_El,2))
Gas_costs.updateCustomSensor(domoticz.utils.round(EURO_Gas,2))
Tax_costs.updateCustomSensor(domoticz.utils.round(EURO_Tax,2))
Total_costs.updateCustomSensor(domoticz.utils.round(EURO_Total,2))
Zuikkis
Thanks! Yes I found something similar already from this forum. I will do it that way.
It's just sad that Domoticz already has cost calculation but it's useless with variable rates...
Zuikkis
Ok everything is working now.
Instead of generic "custom" type for the price counter, I used "counter incremental":
This seems to be working but we'll see until I actually have more data! I just have a cron job that gets last hours Wh from domoticz, calculates price, and feeds this incremental counter with the result. Domoticz then actually calculates daily/monthly/yearly automatically.
The units of "incremental counter" default to kWh but that can be changed: (sorry for the Finnish locale)
.Counter Incremental
/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=1
will increment the counter value by 1. To reset an incremental counter, set the svalue to a negative integer equal to the current total of the counter
Zuikkis
Hmm, everything seems to be working, but daily graph is really messed up if there are negative numbers.
This is the price of my battery use. The price is negative during cheap hours when it's charging, then positive during day when the battery is being used. Apparently the negative values wrap to unsigned integers?
It's only the 24h graph that's incorrect, week/month/year are correct and also the top level shows this which is correct:
HennyN
- Domoticz version: 2024.7
This script I use and does take daily low and high rate periods into account. And uses both in calculation.willemd wrote: Wednesday 23 November 2022 10:56 I am storing the costs components of my contract in user variables and then use a dzvent script to calculate the actual costs. The results are stored in some custom devices. Could that work for you?
on = { timer = { 'every 15 minutes' }},
execute = function(domoticz, device, timer)
local vandaagKwh = domoticz.devices('Power').counterToday
local vandaagM3Gas = domoticz.devices('Gas').counterToday
local StroomKosten = domoticz.devices('StroomKosten')
local GasKosten = domoticz.devices('GasKosten')
local TotaalKosten = domoticz.devices('EnergieKosten')
local KostenE = domoticz.devices('KostenElektra')
local KostenG = domoticz.devices('KostenGas')
local KostenET = domoticz.devices('KostenEnergie')
-- Eenheidsprijs in Euro's / Kwh - M3
local kwhPrijs = 0.22903
local gasM3Prijs = 0.74681
if (domoticz.time == 'Between 23:00 and 07:00') or (domoticz.day == 'Saturday') or (domoticz.day == 'Sunday') then
kwhPrijs = 0.21024 -- Daltarief
kwhPrijs = 0.22903 -- Normaal tarief
-- Vaste kosten in Euro's per dag (zoals vastrecht)
local kwhPrijsVast = 0.70132
local gasM3PrijsVast = 0.54740
-- Kosten berekenen
local KwhKosten = tonumber(domoticz.utils.round( (kwhPrijs * vandaagKwh) + kwhPrijsVast,2))
local GasM3Kosten = tonumber(domoticz.utils.round( (gasM3Prijs * vandaagM3Gas) + gasM3PrijsVast,2))
local KostenTotaal = KwhKosten + GasM3Kosten
local KwhKostenCount = 100 * KwhKosten
local GasM3KostenCount = 100 * GasM3Kosten
local KostenTotaalCount = 100 * KostenTotaal
-- Kosten updaten
StroomKosten.updateCustomSensor(KwhKosten)
GasKosten.updateCustomSensor(GasM3Kosten)
TotaalKosten.updateCustomSensor(KostenTotaal)
KostenE.updateCounter(KwhKostenCount)
KostenG.updateCounter(GasM3KostenCount)
KostenET.updateCounter(KostenTotaalCount)
willemd
The problem with that script is that after 07:00 in the morning it starts to calculate with the normal rate and applies this to the full electricity usage of the day, not only to the usage after 07:00.
Here is my script, now also taking into account the low and high rate. It is only missing low rate of official public holiday's.
Note in my script the elctricity costs are stored in two devices (idx 18 and 105). This is for testing purposes, since I could not derive monthly data from device 18. I am now testing a counter device, to see also what happens when usage goes negative. In the end I will choose one of the two.
-- this script calculates daily costs (update at every new measured value)
-- and adds them to the existing counter value of last midnight
-- it takes into account the periods of low and high rate
-- the rates in the user variables are including BTW/VAT
devices = {
1
timer = {
'at 00:00'
data = {
-- persistent variables, values kept from one script run to the other, also after system reset
EndLowEl = { initial = 0 },
EndHighEl = { initial = 0 },
todayStartElCosts = { initial = 0 },
logging = {
level = domoticz.LOG_INFO,
marker = 'new costcalc',
execute = function(domoticz,item)
-- idx of devices
local idxGasP1=2
local idxElCostsCounter=105
local idxElTaxkWh=4
local idxGasTaxM3=7
-- Input Devices --
-- Variables --
local EURO_El = 0
local EURO_Gas = 0
local EURO_Tax = 0
local EURO_Total = 0
if (item.isTimer) then
domoticz.data.todayStartElCosts=domoticz.devices(idxElCostsCounter).counter
if (tonumber(os.date("%H"))<7) or (tonumber(os.date("%w")))==0 or (tonumber(os.date("%w")))==6 then -- day 0 or 6 is weekend
domoticz.log('before 07:00 ' , domoticz.LOG_INFO)
-- low El_rate
local NettLowEl=(todayEl-todayElreturn)
EURO_El = tonumber(domoticz.utils.round((El_rate_dal * NettLowEl + Delivery_fixed/31 + El_transport),2))
EURO_Gas = tonumber(domoticz.utils.round((Gas_rate * todayGas + Delivery_fixed/31 + Gas_transport),2))
EURO_Tax = tonumber(domoticz.utils.round((El_tax * NettLowEl + Gas_tax * todayGas),2)) + Taxreduction
domoticz.data.EndLowEl=NettLowEl
if (tonumber(os.date("%H"))==23) then
domoticz.log('after 23:00 ' , domoticz.LOG_INFO)
-- low rate
local NettHighEl=domoticz.data.EndHighEl
local NettLowEl=(todayEl-todayElreturn) - NettHighEl
EURO_El = tonumber(domoticz.utils.round((El_rate_dal * NettLowEl + El_rate_normal * NettHighEl + Delivery_fixed/31 + El_transport),2))
EURO_Tax = tonumber(domoticz.utils.round((El_tax * (NettLowEl+NettHighEl) + Gas_tax * todayGas),2)) + Taxreduction
-- normal El_rate
domoticz.log('between 07:00 and 23:00 ' , domoticz.LOG_INFO)
local NettLowEl=domoticz.data.EndLowEl
local NettHighEl=(todayEl-todayElreturn)-NettLowEl
EURO_Tax = tonumber(domoticz.utils.round((El_tax * (NettLowEl+NettHighEl) + (Gas_tax * todayGas)),2)) + Taxreduction
domoticz.data.EndHighEl=NettHighEl
domoticz.devices(idxElCostsCounter).updateCounter(domoticz.data.todayStartElCosts*100+EURO_El*100)
