Python Plugin: Python Plugin Manager
efarmer1
Re: Python Plugin: Python Plugin Manager
Is it possible to install the Python Plugin Manager in a Docker Domoticz setup?
any one got a wiki
any one got a wiki
Gamester17
Please consider adding an option to switch between "stable" and "beta" branch releases for the ZigbeeforDomoticz plugin?
https://www.domoticz.com/wiki/ZigbeeForDomoticz
Main reason is that currently only latest "beta6" branch releases contain support for mentioned Texas Instruments CC253x, CC13x2, CC26x2 Zigbee adapters:
https://github.com/zigbeefordomoticz/Do ... tree/beta6 (beta6 branch is currently their "beta")
https://github.com/zigbeefordomoticz/Do ... ee/stable5 (stable5 branch is currently their default stable)
https://github.com/zigbeefordomoticz/Do ... e-channels
About release channels
In order to provide stability and also provide more recent development, Zigbee for Domoticz plugin has the following channels
- beta6: Current developpement branch integrates zigpy library and allow TI CCxxxx coordinators on top of ZiGate coordinators. Requires Domoticz 2021.1 at minima
- stable5: Support ALL ZiGate models known today and requires Domoticz 2020.x at minima
- Not supported
- beta: deprecated (will be remove end of February 2022)
- stable: latest version 4.11. - Feb. 2021) deprecated
- master: latest version 3.0. - Sept. 2018) deprecated
eddieb
Does the Plugin Manager still work ???
I noticed that 1 of my plugins on github is updated a couple of days ago but the plugin manager does not see that update ...
https://github.com/vaneeten/domoticz-wudirect is updated
I did allready created a github issue on this
https://github.com/stas-demydiuk/domoti ... /issues/33
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
- McMelloW
- Domoticz version: V2024.1
WUdirect is updated to v 0.2.6eddieb wrote: Saturday 09 April 2022 8:32 Does the Plugin Manager still work ???
After you used the plugin manager for update, make sure to restart domoticz and clear cache in your browser. It works OK at my RPi 3b+
Greetings McMelloW
eddieb
I know wudirect is updated, but plugin manager did not see an update ...
I waited 48 hours before I manually updated wudirect
Tjilie
Does anyone know how to fix this?
2022-09-18 12:00:17.820 Error: PP-Manager: Call to function 'onHeartbeat' failed, exception details:
2022-09-18 12:00:17.834 Error: PP-Manager: Traceback (most recent call last):
2022-09-18 12:00:17.834 Error: PP-Manager: File "/home/pi/domoticz/plugins/PP-MANAGER/plugin.py", line 786, in onHeartbeat
2022-09-18 12:00:17.834 Error: PP-Manager: _plugin.onHeartbeat()
2022-09-18 12:00:17.834 Error: PP-Manager: File "/home/pi/domoticz/plugins/PP-MANAGER/plugin.py", line 454, in onHeartbeat
2022-09-18 12:00:17.834 Error: PP-Manager: self.CheckForUpdatePythonPlugin(self.plugindata[Parameters["Mode2"]][0], self.plugindata[Parameters["Mode2"]][1], str(dir))
2022-09-18 12:00:17.834 Error: PP-Manager: File "/home/pi/domoticz/plugins/PP-MANAGER/plugin.py", line 578, in CheckForUpdatePythonPlugin
2022-09-18 12:00:17.834 Error: PP-Manager: if (self.plugindata[ppKey][2] in self.ExceptionList):
2022-09-18 12:00:17.834 Error: PP-Manager: KeyError: 'examples'
Thanks, Michiel
Thanks, Michiel
- pgielen
- Domoticz version: 2026.4
I would really like to learn how to create a new Python plugin for Domoticz. Is there a manual somewhere to help me get going?
Pierre
Pierre
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
Nautilus
This should help, I hope: https://www.domoticz.com/wiki/Developin ... hon_pluginpgielen wrote: Sunday 25 September 2022 21:30 I would really like to learn how to create a new Python plugin for Domoticz. Is there a manual somewhere to help me get going?
Pierre
And you can look for reference from the existing plugins: https://www.domoticz.com/wiki/Plugins
SterkeJerke
I have almost the same issue:Tjilie wrote: Sunday 18 September 2022 14:04 Does anyone know how to fix this?
Thanks, Michiel
2022-11-25 12:32:44.065 Error: Plugin Manager: Call to function 'onHeartbeat' failed, exception details:
2022-11-25 12:32:44.066 Error: Plugin Manager: Traceback (most recent call last):
2022-11-25 12:32:44.066 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 786, in onHeartbeat
2022-11-25 12:32:44.066 Error: Plugin Manager: _plugin.onHeartbeat()
2022-11-25 12:32:44.066 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 422, in onHeartbeat
2022-11-25 12:32:44.066 Error: Plugin Manager: pluginKey = Parameters["Mode2"]
2022-11-25 12:32:44.066 Error: Plugin Manager: KeyError: 'Mode2'
2022-11-25 12:32:54.081 Error: Plugin Manager: Call to function 'onHeartbeat' failed, exception details:
2022-11-25 12:32:54.081 Error: Plugin Manager: Traceback (most recent call last):
2022-11-25 12:32:54.081 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 786, in onHeartbeat
2022-11-25 12:32:54.081 Error: Plugin Manager: _plugin.onHeartbeat()
2022-11-25 12:32:54.081 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 422, in onHeartbeat
2022-11-25 12:32:54.081 Error: Plugin Manager: pluginKey = Parameters["Mode2"]
2022-11-25 12:32:54.081 Error: Plugin Manager: KeyError: 'Mode2'
Harald777
- Domoticz version: Latest
Did you solve this issue already.Thelion wrote: Tuesday 30 November 2021 12:30 Hi,
How do I remove Python Plugin Manager completely?
I removed the folder in the Domoticz Plugin folder, after I removed the hardware, but I still get the Plugins-Manager option in the Custom menu.
Love to know how, I have the same issue after removing the not working alternative Plugins Manager.
Greetings,
Harald
Thelion
- Domoticz version: 2022.1
Yes, I did, but I can't remember how exactly. It's been a whileHarald777 wrote: Sunday 18 December 2022 10:26
Greetings,
Harald
I think I went the way of fiddling with the files and database, after making a backup of course.
- Domoticz version: 2026.3
To remove the custom page remove the plugins manager html from
domoticz/www/templates/
Harald777
Yes, that did the trick.waltervl wrote: Sunday 18 December 2022 18:23 To remove the custom page remove the plugins manager html from
Thanks for this info, much appreciated.
Greetings, Harald
YrBo
- Domoticz version: 2023.2
I installed the plugin manager from https://www.domoticz.com/wiki/Python_Plugin_Manager
When installing a desired plugin the plugin is not installed.
I dont see a folder created at
pi@DomoticzPi:~/domoticz/plugins $ ls
AwoxSMP PP-MANAGER Zigate examples
I followed al the steps, please help...
Nautilus
Hopefully not an issue anymore but you have to restart domoticz and the go to create new hardware. Whatever plugin you installed, it should have created a new entry to the available hardware list for you to select.
domovincent
- Domoticz version: 2026.2
Python Plugin Manager revival
I've forked the pp-manager and refreshed it a bit, making sure it's python 3.9-3.14 compatible, using uv by default for env isolation, with fallbacks if needed.
Added a nicer registry file to the repo.
Removed dead/broken plugins (at first glance) and added some new ones.
Monthly github scan to detect new plugins.
Upgraded the security check to use python ast (still not 100% of course, but better nonetheless).
https://github.com/adrighem/pp-manager
Make sure you install it as 00-pp-manager, because domoticz loads python plugins alphabetically and this one should load first.
Domoticz (RPI 5), Z-Wave, 433, MQTT, ANWB-energy. Happy user since 2017
