Can't find variable: initVersion
Bospieper
Domoticz version: 2026.3
Post by Bospieper »
All of a sudden my Ipad Air2 shows this failure when using Dashticz.
IOS V 15.7
Dashticz version: 3.9.6 beta
I was already using the latest versions when the failure occured.
On my Windows laptop there are no problems.
I've tried another browser on my Ipad but with the same failure.
Grz. Piet
HansieNL
Re: Can't find variable: initVersion
Post by HansieNL »
I got the same problem... viewtopic.php?p=293651#p293651
Blah blah blah
Bospieper
Post by Bospieper »
@HansieNL You don't have any troubles with Windows and Dashticz?
HansieNL
Post by HansieNL »
On Windows no problem.
I just updated iPad to iPadOS 16.1 but still same error message :-(
Blah blah blah
Bospieper
Post by Bospieper »
Hi HansieNL,
A option would be revert to a previous version of Dashticz only I don't know how to do that.
Lokonli
Post by Lokonli »
There was indeed an IOS compatibility issue, which I accidentally introduced with release v3.9.6
I've fixed that in latest version (v3.9.6.1)
It's easy to switch back to previous Dashticz versions. Via the command line:
git checkout v3.9.5-beta
And back to the beta branch:
git checkout beta
Followed by:
git pull
to get the latest version.
HansieNL
Post by HansieNL »
Thanks for the quick fix :D
Blah blah blah
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Problem solved.
Thanks Lokonli
Bospieper
Post by Bospieper »
Thanx for a quick solution :)
Piet
