How to keep historical data when changing battery in weather sensor
Bernd
Domoticz version: 2023.1
Post by Bernd »
I know it is written somewhere in this forum. I used it before with success. But the batteries last too long to remember how I did it.
I searched with different phrases but had no luck.
I have different weather sensors, communicating over 433 MHz and received by RFXCOM. The ID changed from 3000 to A600.
I would like to keep the historical data. How do I do that?
Thank you.
Raspberry Pi 4 2GB (RPi OS Light)
RFXCOM RFXtrx433E, firmware version = 1025
Domoticz version: 2026.3
Re: How to keep historical data when changing battery in weather sensor
Use the replace function to replace the old Domoticz device by the new with including the historical data. See the wiki for instructions: https://www.domoticz.com/wiki/Managing_ ... ace_device
Bernd
Post by Bernd »
YES, that did the trick!
I have printed the guide, for next time ;)
Thank you!
Bernd
Post by Bernd »
May I suggest to change the name of the article "Replace device" to "Replace battery" ?
My search was for battery, which gave no results.
Replace battery is not the only use case to replace a domoticz device. Could also be replacing electricity meters, changing from Zwave OZW to ZwaveJS-UI etc.
