flux_led.py error on domoticz docker
Gravityz
Domoticz version: 2026.3
Post by Gravityz »
i am testing an arilux ledstrip and have problems switching it on/of from a dzvents script.
the flux_led.py script should make it possible to turn the light on/off but i am getting an error
root@Domoticz:/opt/domoticz/userdata/scripts# ./flux_led.py 192.168.1.243 -1
as far as i can tell python3 is default installed inside the docker image.
also the script started with #!/usr/bin/env python2 which i changed into #!/usr/bin/env python3 to let it execute.
anybody see what is going wrong.
if i just execute flux_led 192.168.1.243 --on it works
Last edited by Gravityz on Wednesday 26 October 2022 14:37, edited 1 time in total.
pipiche
Re: flux_led.py error on domoticz docker
Post by pipiche »
Gravityz wrote: Wednesday 26 October 2022 14:27 Hello,
in python3 you should do
print("bla bla bla")
So I think you are just missing parenthesis
Perhaps you have an old python2 version of the script? did you get it from https://github.com/beville/flux_led ?
by the way: arilux flux led strip should be supported by Domoticz by native hardware. So you should be able to select it from menu Setup-Hardware
https://github.com/domoticz/domoticz/bl ... Arilux.cpp
Arilux AL-C0x is a Wifi LED Controller based on ESP8266.
Also compatible with Flux LED or any other LED strip controlled by Smart Home App
Multiple version, RGB,RGBWW, with or witout remote controll
Price is from 5 to 20 euro
Protocol if WiFi and TCP, the rgb controller needs to be connected to your wireless network
Domoticz and the lights need to be in the same network/subnet
Based on christianTF boblightwifi plugin for Arilux and Belville Flux Led python plugin
Gravityz
Post by Gravityz »
ok thanks.
i just discovered that there also seems to be an executable flux_led in /usr/local/bin.
if i call that executable it is working.
maybe the script is outdated
Gravityz
Post by Gravityz »
Hi Walter,
indeed i tried the native version but i experienced lot's of strange things
i could switch the light on/off from the user interface but when i tried it from dzVents it did not work at all.
i could see the light update because the timestamp changed but the light did not turn on.
So the arilux implementation is still not 100%(not for plain switch and certainly not for RGB)
Also in combination with .afterSec or .afterMin it was even more unstable.
now i am using a dummy switch with this in the on command
script:///usr/local/bin/flux_led 192.168.1.243 --on
waltervl wrote: Wednesday 26 October 2022 14:48 by the way: arilux flux led strip should be supported by Domoticz by native hardware. So you should be able to select it from menu Setup-Hardware
