setup for ANPVIZ IPC-D353WD-S
guenniac
Domoticz version: 2023.2
Post by guenniac »
I have successfully setup the CAM with AgentDVR. The connect URL is: rtsp://192.168.11.39:554/cam1/mpeg4.
In domoticz I have tried this
without success. I also played unsuccessfully around with different variations.
Any hints how to proceed?
Günter
Raspberry Pi 3B+
Raspbian GNU/Linux 12 (bookworm) / 6.1.61-v7+
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
Domoticz version: 2026.3
Re: setup for ANPVIZ IPC-D353WD-S
Best is to check if your camera supports a snapshot mode as that is supported in the image URL. eg http://192.168.11.39/cam1/snapshot (fake URL!)
In this wiki page you have some examples: https://www.domoticz.com/wiki/Camera_Setup
Edit: check grab.jpg?oid=1 and command.cgi?oid=1&ot=2&cmd=snapshot from https://www.ispyconnect.com/userguide-agent-api.aspx
