Insecure script command - perl XMPP script
All kinds of 'OS' scripts
witekp
Post by witekp »
I am trying to add an XMPP notification - it is described here:
https://www.domoticz.com/wiki/Installin ... ion_System
I get a message in my logs:
Error: HTTP: Insecure script command!
I agree with that - wrong solution.
However, I am writing a perl script using the excellent library
Net :: XMPP
It's the same!
Script call in domoticz:
script://home/myuser/domoticz/scripts/xmpp.pl #FIELD1 #FIELD2 #TO "#MESSAGE"
How to solve the problem? Of course, running the script outside of domoticz works fine.
XMPP is very important to me. This is not related to the file permissions, I have tried to restrict them.
Has anyone encountered such a problem?
gizmocuz
Re: Insecure script command - perl XMPP script
Post by gizmocuz »
The above script does not give any warning here
You are sure you are using that exact script line?
(For example, it is not allowed to use single quotes)
witekp
Post by witekp »
Thank you for your response.
I didn't have any warnings - only two lines:
022-10-11 23:33:29.415 Status: Notification: Domoticz test
2022-10-11 23:33:29.415 Error: HTTP: Insecure script command!
but, when I turned on syslog in domoticz configuration, i have two additional lines:
 Notification sent (http) => Failed
Active notification Subsystems: browser, fcm, http (3/13)
Maybe I don't have script: // support for notifications? But how can this support be included?
Quotation marks are not a problem, I tried with URL / Action without any parameters:
script://home/myuser/domoticz/scripts/xmpp-t.pl
