Including parameters in script action
janbbe
Domoticz version: 2022.1
Post by janbbe »
For a switch I configured a script action including some fixed values.
In my case I defined the tags " -a -b -c " are used in a Bash script. I can set those tags with a fixed value, for example " -a1 -b2 -c3 ".
So the result in the action line will be: script://test.sh -a1 -b2 -c3 (this works perfect)
My question is, how to change the fixed values 1, 2, 3 in a variable of an anther switch within Domoticz linked on the IDX of that switch. I tried several options but none worked. See for tag "c" below.
So the result in the action line will be script://test.sh -a1 -b2 -c${Idx45} this does not work ;-(
Idx45 is could be a value of a temperature setting.
Enyone who know how to solve this?
Domoticz version: 2026.3
Re: Including parameters in script action
You cannot with action scripts. With dzvents you can run external commands like bash scripts with the executeShellCommand() function, see wiki page
https://www.domoticz.com/wiki/DzVents:_ ... _execution
