- New SD Card
- Current Raspberry installed
- All updates and upgrades
- Last stable Domoticz version installed
- Domoticz is started
- Domoticz finished via putty
- Plugins and scripts copied from backup
- Last db database imported
Now Domotizc starts only always offline
bye
Markus
SD Card defect, new installation after restore offline
- Domoticz version: 2024.7
Re: SD Card defect, new installation after restore offline
from wiki https://www.domoticz.com/wiki/Raspberry_Pi :
WARNING nov 2021: Raspberry Pi OS based on Bullseye is giving issues with Python plugins on Domoticz 2022.1 Stable!! Please do not upgrade or use this OS version for fresh install (instead use Raspberry Pi OS Legacy, based on Buster). Other option is to move to Domoticz Beta version as it is solved in this version.
- Domoticz version: 4.10717
This has something to do with MQTT.
Have installed it but unfortunately it does not work
2022-09-28 18:02:08.076 Error: SellyMQTT: Disconnected from MQTT Server: 192.168.0.184:1883
2022-09-28 18:02:18.097 Error: SellyMQTT: Failed to connect to: 192.168.0.184:1883, Description: Connection refused
That error would not set Domoticz offline.
Is your Domoticz crashing or is it still running but you cannot connect? Did you clear your browser cache as that is the most common solution for user interface issues. Try to access Domoticz with your browser in incognito mode to check.
- Domoticz version: Latest
Perhaps a firewall blocks port 1883 ?ProjektC wrote: ↑Wednesday 28 September 2022 18:03 This has something to do with MQTT.
This was all working so well and now I can't get it to work after hours.
It is a fresh Respberry installation
sudo apt install -y mosquitto mosquitto-clients
sudo systemctl enable mosquitto.service
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
mosquitto -v
1664393794: mosquitto version 2.0.11 starting
1664393794: Using default config.
1664393794: Starting in local only mode. Connections will only be possible from clients running on this machine.
1664393794: Create a configuration file which defines a listener to allow remote access.
1664393794: For more details see https://mosquitto.org/documentation/aut ... n-methods/
1664393794: Opening ipv4 listen socket on port 1883.
1664393794: Error: Address already in use
1664393794: Opening ipv6 listen socket on port 1883.
sudo mosquitto_passwd -c /etc/mosquitto/passwd mqtt
sudo nano /etc/mosquitto/mosquitto.conf
per_listener_settings true
pid_file /run/mosquitto/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
allow_anonymous false
listener 1883
password_file /etc/mosquitto/passwd
sudo systemctl status mosquitto
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2022-09-28 21:32:40 CEST; 7min ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Main PID: 3339 (code=exited, status=1/FAILURE)
CPU: 58ms
Sep 28 21:32:40 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Sep 28 21:32:40 raspberrypi systemd[1]: Stopped Mosquitto MQTT Broker.
Sep 28 21:32:40 raspberrypi systemd[1]: mosquitto.service: Start request repeated too quickly.
Sep 28 21:32:40 raspberrypi systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Sep 28 21:32:40 raspberrypi systemd[1]: Failed to start Mosquitto MQTT Broker.
I don't understand why this does not work
mosquitto -v
persistence true
listener 1883
man:mosquitto(8)
CPU: 58ms
So now Buster installed but has brought nothing.
listener 1883
removed and then it worked
There are unfortunately many sites that write even with 2.0.11 it must be in.
listener 1883
