Reading lux sensor
pkelderman
Domoticz version: 2024.4
Reading lux sensor
Post by pkelderman »
Does somebody know how to retrieve the number of lumen/lux from a lux sensor? Thanks at forehand! I want to use it in a lua-script.....
Toulon7559
Domoticz version: <2025
Re: Reading lux sensor
Post by Toulon7559 »
Which type/model of lux-sensor?
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
In Dzvents it is like this
execute = function(dz)
local lux           = dz.devices(454).lux
if lux = 100 then .....
454 is of course your device number
pkelderman
I'm using a ZW100 Multisensor 6+ from Aeon Labs; the same brand as my controller, that's a ZW090 Z-stick Gen5 from Aeon labs. Need more info? Please tell me?
Last edited by pkelderman on Monday 12 September 2022 19:12, edited 2 times in total.
pkelderman
I tried;
current = otherdevices_humidity[TempEnVocht]
current = devices(Lichtsterkte)
the first one works, the second gives:
2022-09-12 19:09:00.140 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_PIRs.lua: /home/pi/domoticz/scripts/lua/script_time_PIRs.lua:29: attempt to call a nil value (global 'devices')
madpatrick
pkelderman wrote: Monday 12 September 2022 19:11 I tried;
You need to add .lux after device name
 current = devices(Lichtsterkte).lux
pkelderman
I have tried:
local Lichtsterkte = 'Lichtsterkte'
print(current)
The log says:
2022-09-13 14:35:00.160 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_PIRs.lua: /home/pi/domoticz/scripts/lua/script_time_PIRs.lua:34: attempt to call a nil value (global 'devices')
madpatrick
pkelderman wrote: Tuesday 13 September 2022 14:38 I have tried:
print(current)
The log says:
Can you post the complete script.
I'm aan NoNo on Lua and little bit better in Dvents, but maybe i can assist in getting you in the right direction
azonneveld
Post by azonneveld »
Try:
current = tonumber(otherdevices['Lichtsterkte'])
Then don't use:
if current==100 then
But use f.i.
if current >90 and current <110 then
Chances are the value of 100 is skipped due to the refresh interval.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
willemd
Domoticz version: 2024.1
Post by willemd »
madpatrick wrote: Monday 12 September 2022 19:17
And "dz.devices" instead of just "devices"
jvdz
Domoticz version: 4.107
Post by jvdz »
willemd wrote: Tuesday 13 September 2022 17:17 And "dz.devices" instead of just "devices"
Think this is a regular LUA time script looking at the script path, so otherdevices is the arrayname to use!
Jos
pkelderman
@ asonneveld
I tried next solution:
print(current)
the result:
39
Wow it works! Thanks a lot!
