I finally found a solution for a rain meter that immediatly detects rain at the start, not like typically bucket sensor which need a few minutes before first detection. I made a topic on a dutch forum, but Google Translate will do the trick for sure.
Enjoy!
https://gathering.tweakers.net/forum/li ... s/2146234
Rain sensor that detects rain immediatly
solarboy
- Domoticz version: 2026.4
Re: Rain sensor that detects rain immediatly
Nice discovery. I am using a Kemo M152K quite succesfully with a Sonof switch module module although it is quite expensive.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
solarboy
https://cpc.farnell.com/kemo-electronic ... dp/HK01739
They do a non capacitive version which I found to be unreliable, even using run-off water rather than direct rain.
