rfxtrx: losing sensor connection after replacing the old one
epierre
Post by epierre »
For some time (some months now) I keep on losing the sensor when replacing the old one.
For example this morning I added in the UI the live sensor in device (not used) then replaced the old one anf from this moment it stopped receiving data and a new one poped up in the unused devices.
I kept on updating toward latest domoticz beta with no improvements.
I have this for two Temp+Hum from oregon scientific. any idea of the issue ?
RFX data and conf:
2022-08-25 09:25:23.936 Transceiver type = 433.92MHz
2022-08-25 09:25:23.936 Firmware version = 1025
2022-08-25 09:25:23.936 Firmware type = Type1
2022-08-25 09:25:23.936 Hardware version = 1.1
2022-08-25 09:25:23.936 Undec off
2022-08-25 09:25:23.936 X10 disabled
2022-08-25 09:25:23.936 ARC enabled
2022-08-25 09:25:23.936 AC enabled
2022-08-25 09:25:23.936 HomeEasy EU disabled
2022-08-25 09:25:23.936 Meiantech/Atlantic disabled
2022-08-25 09:25:23.936 Oregon Scientific enabled
2022-08-25 09:25:23.936 ATI/Cartelectronic disabled
2022-08-25 09:25:23.936 Visonic disabled
2022-08-25 09:25:23.936 Mertik disabled
2022-08-25 09:25:23.936 AD disabled
2022-08-25 09:25:23.936 Hideki enabled
2022-08-25 09:25:23.936 La Crosse disabled
2022-08-25 09:25:23.936 Legrand disabled
2022-08-25 09:25:23.936 MSG4Reserved5 disabled
2022-08-25 09:25:23.936 BlindsT0 disabled
2022-08-25 09:25:23.936 BlindsT1 disabled
2022-08-25 09:25:23.936 AE disabled
2022-08-25 09:25:23.936 RUBiCSON enabled
2022-08-25 09:25:23.936 FineOffset disabled
2022-08-25 09:25:23.936 Lighting4 disabled
2022-08-25 09:25:23.936 Conrad RSL disabled
2022-08-25 09:25:23.936 ByronSX disabled
2022-08-25 09:25:23.936 IMAGINTRONIX enabled
2022-08-25 09:25:23.936 KEELOQ disabled
2022-08-25 09:25:23.936 Home Confort disabled
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
gizmocuz
Re: rfxtrx: losing sensor connection after replacing the old one
Post by gizmocuz »
Not sure if I follow you a 100% but
- first connect the device to your computer and use the RFXMngr application to see everything is correctly received and the correct protocols are enabled
- next connect the RFXtrx to your domoticz system, make 100 sure you have a powerfull USB adapter if you use a raspberry PI or simular..
- make sure in domoticz you have only configured one RFXtrx hardware
- in domoticz use the serial/by-id as communication port, avoid using /dev/ttyUSBxx as they might switch after a reboot
- make sure that you have entered 0 as data timeout
In the settings , enable 'accept new hardware for 5 minutes (or just enable it)), make sure your (two) sensors are received, next disable accept new hardware
Now everything should continue to work just nicely!
epierre
Post by epierre »
I did exactly what you said before with no result.
my system has 20+ rfxtrx oregon and alike. The only thing I've never done in 10 years is to push the reset button on the device while changing battery.
hmmm... behavior since Stable 2022.1 ... seems it is something I've not seen before will try this
