Error: dzVents: Error: (3.1.8) Method setColor is not available for device "Saunan valo" (deviceType=Light/Switch, deviceSubType=Switch). If you believe this is not correct, please reportModerator: leecollings
Error: dzVents: Error: (3.1.8) Method setColor is not available for device "Saunan valo" (deviceType=Light/Switch, deviceSubType=Switch). If you believe this is not correct, please reportCode: Select all
http://Domo-IP:PORT/json.htm?type=devices&rid=IDXCode: Select all
"ActTime" : 1666793588,
"AstrTwilightEnd" : "20:06",
"AstrTwilightStart" : "06:08",
"CivTwilightEnd" : "18:24",
"CivTwilightStart" : "07:49",
"DayLength" : "09:04",
"NautTwilightEnd" : "19:15",
"NautTwilightStart" : "06:58",
"ServerTime" : "2022-10-26 17:13:08",
"SunAtSouth" : "13:07",
"Sunrise" : "08:35",
"Sunset" : "17:38",
"app_version" : "2022.1 (build 14498)",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"DimmerType" : "abs",
"Favorite" : 0,
"HardwareDisabled" : false,
"HardwareID" : 7,
"HardwareName" : "Zigbee2MQTT",
"HardwareType" : "Zigbee2MQTT",
"HardwareTypeVal" : 94,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0x842e14fffe065fe1_light",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2022-10-26 10:31:49",
"Level" : 100,
"LevelInt" : 100,
"MaxDimLevel" : 100,
"Name" : "Saunan valo",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" :
2
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : 4,
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "dimmer",
"Unit" : 102,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "172"
"status" : "OK",
"title" : "Devices"Code: Select all
"ActTime" : 1666793825,
"ServerTime" : "2022-10-26 17:17:05",
"Sunset" : "17:38",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"ID" : "0x842e14fffe57d342_light",
"Image" : "Light",
"LastUpdate" : "2022-10-26 10:28:47",
"Level" : 100,
"LevelInt" : 100,
"Name" : "Saunam\u00f6kin eteisen valo",
"PlanID" : "11",
"PlanIDs" :
11,
2
"SignalLevel" : 4,
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 15,
"Used" : 1,
"XOffset" : "28",
"YOffset" : "903",
"idx" : "38"
"status" : "OK",
"title" : "Devices"Yeah, but that is the one that was workingwaltervl wrote: Wednesday 26 October 2022 17:16 Indeed, the only worrying difference is the use of a backslash in the name of the second device "Name" : "Saunam\u00f6kin eteisen valo" which perhaps triggers an unexpected parsing issue in dzVents
